Results 1 to 7 of 7
Thread: vt berlina gear problem
    VT berlina
    Mar 2009
    Default vt berlina gear problem
    hey guys, sorry if this issue has been covered before. I checked with the search tool but couldn't seem to find an answer. ok, so I just recently bought my first car it's a 98 vt berlina. I've had it for a few weeks now and last night I was cruzing down the highway just comfortably sitting on about 100 on flat road wen my car jus decided to drop back to third and continued to stay there. I pulled over after a while and put in park with the car still turned on. I then took off after a few minutes to see if the problem had sorted itself out but sadly It still wouldn't get past 3rd. it wasn't untill I stopped at the shops, turned my car off, did my shopping, came out and drove back home that it had seemed to have fixed it self. I drove around today and seems to be fine. just wondering is this a common problem and should I be worried? any help would be great. my car is a 1998 vt berlina automatic with 170,000 on the clock if that helps. cheers.
    VT berlina
    Mar 2009
    mwb235 Guest
    My VR used to do that whenever i was towing a really heavy load. This sounds like the overdrive isn't working properly and shifting it down to 4th but I don't really know, sorry.
    custom vk Calais
    Jan 2009
    VT berlina
    Mar 2009
    na the power button wasn't on. it's got me stumped, I've checked the trans fluid and it's all good. maybe I should jus take it to a mechanic and get the auto serviced or something. it's been fine since it happened the other day though so maybe it was just a one off thing, I hope.
    VT spac super6
    Nov 2008
    Riverton sa
    common symptom, when was the last time it was serviced?
    and its more than likely the heat override for overdrive, if the trans runs hot you lose overdrive
    i delt with it for ages because the trans slipped under load, got hot and bam no overdrive
    VT berlina
    Mar 2009
    I've got no wen the trans was last serviced as I only just bought it a few weeks ago and I wasn't told alot about it's history. I think I'll just take it in for a service and get it checked out. thanks for the help guys. cheers.
  1. vs gear box problem
    By scoota72 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2009, 06:03 PM
  2. Problem in 4th gear
    By thieled in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2009, 08:33 PM
  3. Gear box problem????
    By clazzza commy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2009, 08:14 PM
  4. Auto Gear shift problem?
    By 2h1bb1 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-11-2007, 11:18 AM
  5. 4th Gear problem
    By upthetiggers in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2006, 01:45 PM
