Results 1 to 6 of 6
Thread: vt starting problem
    vt
    Jul 2009
    Default vt starting problem
    Hi, Got a big mystery on my hands.
    Have problems with the car not starting .Turns over just wont start. .Visited multiple mechanics They give up . Had almost everything replaced from the ignition switch and key to the fuel pump .Nothing shows up on comp check . Will start ok for a week then decides it wont start and you can try to start it for another week with no luck and out of the blue it will start again. Once it is going it runs well . May be ok for another day or maybe a week then it happens again.
    Any ideas what this could be. Its driving me crazy and i cant afford to be repeatedly paying for tow trucks and repairs that dont work.
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Is it stock? Any aftermarket pod filter?
    Have you changed the o2 sensor and MAF?
    lion_g is offline LionG
    VT Executive Series II 3.8/V6
    Jun 2009
    T'Ville
    Hey mate, i had the same thing. Then engine rolls over but pistons dont fire?
    Check ur crank angle sensor and harmonic balancer
    VT Acclaim Series 2
    Jun 2009
    my brother had the same problem on his commodore...it was a vn thou, anyway he got the earths (one on the body and the other on the engine) cleaned and his problem was fixed.....might wanna give it a try....you got nothing to lose execpt 5 minutes of your time. also might wanna make sure all you cables running from the computer are firmly in place...or it could be a problem with the computer itself.
    VX Executive S2
    May 2006
    Frankston South Vic
    VX
    May 2009
    +1 Crank Angle Sensor
  1. VT 5.0 starting problem
    By jb2020 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-08-2008, 11:22 PM
  2. starting problem
    By djeyecon in forum V6 Development And Modification
    Last Post: 29-07-2008, 11:13 PM
  3. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  4. Help Please.v8 Starting Problem
    By v8srbad in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2007, 07:59 PM
  5. VS starting problem
    By mrnathan in forum Electrical Wiring / Questions
    Last Post: 06-06-2006, 09:46 PM
