Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: Door and Window squeaks. The final answer.
    VT S2 wagon Berlina
    Dec 2008
    Default Door and Window squeaks. The final answer.
    I've been looking over the whole site for hours now and there seems to be no sure fire way of fixing the squeaks in the VT doors and windows.
    I have a VT s2 (wagon) with the felt rubbers and it still squeaks.
    I want to get this post to just list the top 5 or 6 fixes in the one spot.
    The VT is over 10 years old now so surley someone has a 99% sure fire solution (no not buy another car).
    This squeak is really pee-ing me off.
    Lets knock this subject on the head.
    Thanks
    Darren
    kart_racer is offline Races karts
    VT Acclaim 5M
    May 2008
    The last few threads on here don't seem to go into it, but the door strikers on the VT tend to lose their plastic covers, allowing the latch to have movement on the striker.
    I haven't tried new strikers yet, but I have experimented with belt grip & adjusting the strikers.
    Belt grip applied to all the rubber seals seems to take away a bit of movement. The big bumps still cause the door to rattle, but at least it shuts up the constant rattling with normal movement of the car. Eventually the rubbers get dusty or the belt grip loses its grip and the doors start rattling again. It's easy to apply though. Oh, the other thing is it leaves yellowish marks on the paint where the rubber seals contact. Can be cleaned off with prepsol.
    I also moved the strikers on the front doors inwards, to make the door shut tighter against the frame. This seemed to take away most of the movement too, but can make the doors harder to catch the latch properly and make them misaligned with the body/other doors.
    Other things that have been suggested are silicone spray, which i expect does the opposite of belt grip and allows the rubbers to move more freely. Also, a strut brace minimises flex in the front of the body so the doors have less movement.
    The window is another story. There is a hex screw adjuster on the back of the door that adjusts the position the window stops at when right up. This can stop creaks and rattles in the window when wound up.
    When wound down, there are plastic runners in the window tracks that wear away/break and allow rattling. Also there is a fix of putting an extra washer in the lower mountings to move the window away from the regulator.
    I haven't done this, I just keep my window up as much as I can
    VX 'S' S1
    Apr 2005
    South East,Victoria
    The problem with the VT onwards is that the firewall is laminated in place instead of welding it which makes the body flex more.
    VT Acclaim 5M
    May 2008
    Quote Originally Posted by Dayvo View Post
    That's a problem from VN onwards . In fact the VT onwards are bonded a bit better than the previous.
    Hey Darren, how's the manual wagon going
    VT Executive V6
    Jul 2009
    Default Seems to reduce window squeaks!!!
    I have suffered from squeaking windows that only worsened as the suspension was hardened and tyre profiles thinned. A strut brace gives a much tighter front end and stops "doorbanging" when going really hard at HIGH speed.
    Try McGuire's Trim Detailer. Get in and clean, clean, clean the rubber around the windows and especially across the top of the door trim. Dry and apply the McGuire's. After a month or two and a few applications the rubber softens up and loses the hard, squeaky surface. Any rubber on rubber with wax or detergent will sqeak so it may take you a couple of goes to find all of the spots.
    VT S2 wagon Berlina
    Dec 2008
    ok
    moved door latch in a bit. seems to help some . The plastic bit was worn.
    anorak do you mean the inside door trim or the outside of the car.
    thanks
    VT S2 wagon Berlina
    Dec 2008
    bloody god dam window sqweeks are driving me around the f ing bend.
    My window goes tick tick tick when it gets the sun on it.
    the top of the window right near the b piller squeaks over every bump.
    its driving me sh1t crazy.
    STOP IT JUST STOP IT FOR CHRIST SAKES.
    ok settled down now. need a fix.
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    at 100kmp/h i have a constant whistle that even my sound system cant make it disapear now that is annoying! my doors also squeek but im used to that....
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    my vn's doors rattlen their jams.... hows this fixable
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    wind your window up till it wont go any further, then drop it down about 4-6mm and the rattle and squeaks disapper
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    I've been told it's the tabs at the top of the door frame - remove the rubber in the top of the frame and adjust the tabs down a little. I have not tried this myself - but can see how they let the window rattle/squeak.
    Side note - I had a very annoying squeak left front door on my VN wagon a few years ago. To stop it I put masking tape on the door rubber along the bottom of the door. Squeak stopped. It was the paint finish on the door (repainted in 2 pack). Put a different door rubber in - no fix - put tape back on it. The tape jhas perrished in place now - but no squeak.
    and 3 Dangerous non ABS VN's
    VT S2 wagon Berlina
    Dec 2008
    do you have the black plastic on your door clamp. the bit on the B pillar that the door shuts on. mine had worn away and clunked as well as poke the door out a bit.
    got an allan key and moved it in a bit problem fixed.
    VX Lumina V6
    Feb 2010
    Quote:
    "The window is another story. There is a hex screw adjuster on the back of the door that adjusts the position the window stops at when right up. This can stop creaks and rattles in the window when wound up. "
    Can someone please post a picture or diagram of where this screw is? I can't seem to locate it. My passenger window is driving me batty also.
    87LAG's Avatar
    87LAG is offline BOOSTED 6 FTW
    VX S S2 AUTO RAPTORCHARGED
    Apr 2010
    THE SWITCH
    you have to wind the window down half way to see it. its a allen head bolt just loosen it it off push up 3-4 mm. i did this to my vx fixed a slight water leak problem and window squeaking. . . . . gl
    also this thread should be put in how to's or were ever these go sticky
  15. #15
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Its a lost case... Everything rattles in a VT, exspecially when lowered with stiffer shocks it tends to get worse.
  16. #16
    vn_v6's Avatar
    Aug 2009
    victoria
    Quote Originally Posted by darren44 View Post
    what wheres is this? im lost
  17. #17
    Dec 2009
    VN's without central locking have the plastic coating which falls off, if they have centreal locking then I don't think they have the plastic. If the plastic is missing and the striker is not loose on its backing plate just tape it with electrical tape it works for years.
  18. #18
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    What's the graphite stuff like? I imagined it to be a dry powder that would be ideal for the felt seals that the windows seat against when closed? The vy gives a slight squeek here and there too, and I wondered about the graphite. I use armour all on all my rubber seals, but not sure about what to use on the felt coated rubber.
  19. #19
    VX Lumina V6
    Feb 2010
    If you use graphite, you'll get black sh!t over your hands and clothes. Try silicon spray; makes for easy sliding on sticky windows.
  20. #20
    VX Lumina V6
    Feb 2010
  21. #21
    VE SS Sportwagon
    Feb 2010
    Brisbane - Southside
    yeah, i did the graphite once...what a mess.
    Silicone spray seems to quiet down some of the noise, but my drivers side window strill creaks and craps me to tears.
    I've checked and none of my strikers have the black plastic, and I don't remember if it ever did have it. I bought the car new in '99.
  22. #22
    vt commodore
    May 2010
    Had a really anoying grinding noise [like the window channels were full of sand ] every time you operated drivers window. Pulled the door trim off and found one of the plastic regulator sliders had broken in half, the arm closest to the outer door handle was'nt even in the window channel, still operated perfect, just bad noises. Had a 2nd hand door off a vs lying around, popped the plastic slider off, wasent easy 2 big screwdrivers put it in my window channel lubed it up with bearing grease and squeased the ball in with a pair of multi grips. Window has never sounded better, not a squeak or groan.
  23. #23
    VE Lumina
    Sep 2009
    Can I please have some feedback on a slight rattling noise which appears to be coming from the passenger side window of my VE mostly prevalent on an uneven road surface (when window is completely closed)?
    Your feedback will be appreciated!
  24. #24
    vx custom 600RR
    Oct 2010
    i have the final answer my car no longer creeks
    1. clean the rubber seals with wd40 or similar and i mean clean them
    2. get a stiff brush and clean/scrub all door flock tape and you'll get dust coming of them
    3. adjust the window there's a 3 mm hex screw adjustment at the top of every window loosen them drop the window an inch then fully closed and tighten the scew
    4. enjoy quite driving
  25. #25
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I used vaseline on the windows to stop them annoying me. Worked for about 3 4 months, but nothing ever stops it for good.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  1. [WA] Fs: Vt white drivers side door with window,door skin &mirror - $60 - perth
    By Timzo in forum Parts And Other Items For Sale
    Last Post: 12-01-2009, 07:59 PM
  2. VY Instrument Clusters. Want a Final Answer for All!
    By vyterra in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-03-2007, 04:50 PM
  3. Commodore vy s squeaks
    By boness in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-06-2006, 09:23 PM
  4. Dash squeaks
    By Roh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2005, 11:03 AM
  5. Squeaks and rattles
    By chum in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2005, 09:52 AM
