I'm looking to lower my car in the future, just wondering what I will need.
My car is a Series 1 2000 VX Commodore S, so I don't think it has IRS. It's on FE2 springs at the moment, and I want to go SSL at the back and SL at the front. I know I will need to buy the SSL back and SL front springs, and I will need a camber kit. Will I need a 2 point or 4 point camber kit? Is there anything else I need other than the springs and the camber kit?
Cheers,
Chris.
As your car is a series 1 VX you will need the 4 point camber kit. As well as this and the springs you will probably need short body shocks (especially at the SSL end). This will help with ride and handling.
it has IRS. Get a 4 point camber kit. You don't NEED them but shortened shocks would be a nice idea
no longer a hoon by association - the commodore is gone
Ok and what brand of shortened shocks would you recommend. Monroe?
irs live rear ends start on the early vs's im pretty sure, i got BOGES shortened shocks in my vz with king springs all round..dropped 50mm all round and rides great with a bit more firmness, wouldnt like to see it if i didnt get the shortend shockys..would be way to stiff i think. 4 point camber kit, springs, shortend shocks, and labour would be a ball park figure of 1200ish
Sticking a Chev badge on any Commodore is like putting a Nissan badge on a VL
EOI....VE SS 18" wheels x4 with 5000k's on new tread, 2 of have very minimal gutter rash (previous owner) otherwise like new send me a pm if interested.
. 2 point camber kit (there are only camber scrub issues in commodores and when lowering them)
.your shockers will wear quicker with lower springs, so get some lowered shockers straight away or after they wear
.in terms of the front, lowering your ride outside the standard suspension geometry (your car is set up for FE2 suspension) may also throw your front end wheel alignment out of whack. (however a front end wheel alignment needs to be done when a rear wheel alignment is done to prevent your car from 'crabbing'). An adjustable radius/strut rod to chassis bush could help, castor wise. I'm going for the Nolathane brand, like many others, but will be keeping my ride height the same![]()
