Results 1 to 20 of 20
Thread: sounds like cam shaft???
    vt acclaim
    Jul 2009
    Default sounds like cam shaft???
    i have a 99 vt which when it gets to 2500 rpm starts makeing a pinging sound im told it could be a cam shaft problem any one know of any thing similar any help would be great!!!
    VP Executive R-spec
    Jan 2005
    vt acclaim
    Jul 2009
    Default ???
    my mechanic up the rd (dodgey rippoff prick) reckons it a cam shaft balencer or some shit like that
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    vt executive
    May 2008
    matey ive just been ****ed over by a mechanic where im now having to replace my motor and with your own words there "DODGEY RIPOFF PRICK" i suggest you do not return to him again post up your area and maybe some of the guys here that no your area can put you onto some reputable mechanics
    good luck
    vt acclaim
    Jul 2009
    VT 2
    Nov 2008
    Yeah there is no such thing.
    Your cam timing might be out, Your electronics could be all ballsed up, but it's will be extremely hard to tell from this side of the ocmputer.
    Pinging can be 2 things - 1 is simply a mechanical sound, something touching on something else. The other is 'Pinging' as in pre-ignition where you timing gets over advanced, and the fuel air mix spontaneously ignites before being set off by the spark plug. Pre-ignition is bad and will destroy engines.
    If it's a mechanical sound, theres no way to tekll from here what it is.
    If it's pre-ignition, you have to look at timing and fuel. A mixture way too lean will pre-ignite, so will dosgy timing. Alot of things can cause these symptoms.
    VY SII HBD Calais L67
    Dec 2006
    Quote Originally Posted by dvs18u View Post
    well im now told its a cam balencer any thoughts?????
    I think you mean "balance shaft"? This runs above the cam in a seperate cavity and they are known to get a rear bearing fault sometimes. Only way to know is to remove the intake manifold and have a look around
    VYII Calais L67
    vt acclaim
    Jul 2009
    yeah i think so but i wish i had the money to do it at the moment can u provide any more details would be great help!!??!!??!!??
    Dec 2006
    vt acclaim
    Jul 2009
    vt acclaim
    Jul 2009
    hey guys any one know where to get a vt workshop manual from????
    i stiil had no luck with this car now its missing done spark and leads now thinking cas or dfi coils are all ok checed with multimeter they are all around 6.3 mark any ideas
    DVS's Avatar
    DVS
    DVS is offline D̮̯͓͂͌ͤͬ̌ͣ̈ͧͩ̃͐ͩ͛̔̀͛̑ͯ ͎̞̜
    VT V6
    JigSaw Puzzle Monkey Champion!
    Jun 2004
    There are two places to check on the coil packs. Primary and secondary.
    Primary - Between 0.3 to 1.5 Ohms.
    The coil pack must be unscrewed and you will see underneath where you can
    test. You may need pins and alligator clips to test.
    Secondary - Between 5,000 to 7,000 Ohms
    This is on top of coil pack where spark plug leads connect too.
    One of my coil packs was faulty reading 0 Ohms. Hope this helps in some way
    vt acclaim
    Jul 2009
  15. #15
    Dec 2006
    can u tell me where exactly the cas is im having trouble finding it
    It's behind the balancer on the right of the crankshaft snout between that and the aircon. Balancer off job and two studs later it will be off the block
    VYII Calais L67
  16. #16
    vt acclaim
    Jul 2009
    if there is any one on here that knows about lpg system faults can u msg me plz i have a few q's
  17. #17
    vt acclaim
    Jul 2009
    also i think i have a ignition issue a while back i had a miss on 1 cyl new plug fixed it now i got a miss again but it not leads spark or coils!!!!! the only other thing i can think of is dfi but im not sure if there is any thing else i can do any ideas
  18. #18
    VT 2
    Nov 2008
    Clogged injector ? not sure with LPG. Clogged injectore in a petrol ingine can mean too lean a burn in one chamber, which will ping / miss.
    Now that I think about it, a stuffed injector will cause a miss in 'too much flow' situations too.
  19. #19
    vt acclaim
    Jul 2009
    it also seem that when it gets hot it loses al the accel and power i becomes a gutless dog any thoughts?????????????
  20. #20
    vt acclaim
    Jul 2009
    when my vt gets hot i think its more when the trans gets hot i got stuff all in tyhe way of power any sugg's i got a feeling i might need a new gbox but would rather not have to spend if i can avoid it any idaes guys????
  1. Sounds like a wrx!
    By blacknight in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2009, 01:38 PM
  2. Help, My VT sounds like a lawnmower
    By U2Bono in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2007, 08:39 PM
  3. VP sounds to REV HIGH
    By ir8prim8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2006, 09:37 PM
  4. car engine sounds please
    By Coxy_vs in forum The Pub
    Last Post: 27-05-2006, 02:47 PM
  5. Sounds Better... Looks Better...
    By jazza21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2004, 12:41 PM
