Results 1 to 4 of 4
Thread: V6 on gas?... check this
    VT Executive S2 3.8 Ecotec
    Jun 2009
    Default V6 on gas?... check this
    Next time you're under your VT V6, run your fingers over the rack & pinion dust boot at its closest point to the driver's side exhaust pipe.
    It's a spot that you can't normally see.
    I did (nothing on TV) & found a hole burned through the plastic dust boot.
    Ingress of grit & water would have destroyed the steering rack had it gone un-noticed.
    Maybe it was caused by gas burning hotter than petrol?
    I wonder if anybody else has found this problem; perhaps not only on VTs?
    VT Twin Turbo
    Jun 2009
    Frankston
    i dont think it would be the gas are you sure its a burt hole a not just the boot being old and perished.
    Jun 2009
    Sorry so long.
    3 cm diameter hole closest to pipe.
    Remaining rubber of boot in good condition.
    Can't think why else it would fail there.
    VX Berlina, VS Exec
    Mar 2005
    Got a GEN3?
    Theres a link 'VS_Omega' posted at the top of the VT-VX forum for typical faults:
    Faults - VX Suspension
    Steering Rack Boots (Gen III) - Some VX steering rack boots may be damaged by excessive heat from the exhaust system. VX's with extractors are more susceptible to heat damage. Revised silicone steering rack boots were released and are more durable.
    Steering Rack Boot - Part number 92146712
    Well noticed tho, good nothing was on TV
  1. to check or not to check..
    By goat in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2009, 08:53 AM
  2. Ha ha check this out!
    By Bravotwozero in forum The Pub
    Last Post: 28-03-2008, 08:13 AM
  3. Check this out!
    By JD in forum The Pub
    Last Post: 27-09-2007, 08:40 PM
  4. Check this out
    By CHANDLC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2007, 06:30 PM
  5. Can ya check for me.....
    By NORTI in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-09-2006, 07:04 PM
