I just bought my altezza headlights. I've got a few questions.
1. From the projector lense there are a few wires coming out of the grommet that connect to a little black box that connects to a ground wire with a fuse in the middle. What does the little black box do? and so i ground the wire? some people say not to ground it or you'll blow the bulbs.
2. When you remove the grommets for the projector lense and the highbeam there are wires to connect to the bulb. But the turn signal light thing does not have a grommet or any wires to connect to the bulb. WTF is all that about?
1. yes you do ground them you should of got instructions in the box if you bought them new
2. you use your turn signal light (from mem) been a while since i put mine in
I'm not slagging off Altezza stuff here (even though i HATE it), but what are Altezza HEADLIGHTS?
Can't say i have seen them before? Do they look different to normal headlights? Got any pics of them?
Originally Posted by wikky
yep, they are brand new and came with instructions which tell you to ground them. But i've heard some ppl say not to coz you'll blow your light bulbs every now and then.1. yes you do ground them you should of got instructions in the box if you bought them new
but dont the wires have to come from inside the headlight assembly? the altezza doesnt have any. Also what do i use for a dust cover? it didnt come with a grommet for that one.2. you use your turn signal light (from mem) been a while since i put mine in
ok well i have had mine in and grounded since i got them about 10 months ago now no problms as for the blinker i will check tomoz for ya i think mine came with a dust boot not 100% to dark and cold to go friggen about now tho
