Results 1 to 5 of 5
Thread: cutting out during journey
    VZ Exec Wagon 2007 3.6L
    Sep 2008
    Broken Hill NSW
    Question cutting out during journey
    ok i will start here.. driving along the highway doing 110-km/h on cruise control for at least an hour or two non stop, so middle of now where at random. the cars revs die and the motor sounds like it has had the cruise taken off and the engine light comes on. then wham its back on all systems go cruise on where i left it everything sounds sweet again. sometimes the revs just go up a thousand rpm while still keeping the same speed. when this happens no light comes on, it just returns to normal rpm for the speed im doing. i had holden check out the error codes and they said that the fuel canister sensor (an error message occured) had a problem. also the MAF had an error also. the bloke told me that if something goes wrong somewhere it can cause sensors to have errors elsewhere. understandable commonsense i suppose. it can happen anytime not just under cruise but it seems to happen more often after i been cruising for a while. i replaced the rear wheel speed sonsors thinking it might be that. maybe its the gearbox giving in. i give the gearbox a service ie filter and gasket change, all looked ok. fluid level fine. maybe its the abs unit or the fuel cannister itself. racking my brain here. i need some answers. lost lost lost.
    vx supercharged
    Feb 2009
    Sep 2008
    Broken Hill NSW
    VX berlina
    Dec 2008
    Sounds hot. Go hard or drive a fruit juice car (2 Lt.) my mate has been EPA'd heaps. they get a decibel meter from like 5M away and it has to get get under 60Db at 3000 RPM those numbers are probably wrong but they're not far off.
    Pete SS's Avatar
    Pete SS is offline Resident Pomme
    VU SS M6
    Oct 2008
    Sydneys East
    What??!?!?!
  1. nearly cutting out
    By COMMY VP 666 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-06-2009, 08:57 AM
  2. Cutting Sub Box
    By owen18 in forum Car Audio
    Last Post: 04-03-2009, 01:19 PM
  3. cutting out
    By [JUDGE] in forum Car Audio
    Last Post: 18-11-2007, 09:01 AM
  4. VR ss cutting out
    By SERGE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2007, 12:12 PM
