Results 1 to 11 of 11
Thread: 3 beeps 3 times
    Vx Executive
    Jun 2009
    Default 3 beeps 3 times
    Hey all,
    I have an issue with my holden commodare vx executive.
    When I turn the engine on after a minute or so I get three beeps three times (so nine beeps in total). No warning lights show and the car runs fine.
    The stop light on the rear window at the top, the rear wiper and the boot light doesn't work but no fuse seems to be blown, could that be it?
    Anyone any idea what could possibly be the cause?
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    What CD player do you have?
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Vx Executive
    Jun 2009
    Quote Originally Posted by STEALTHY™ View Post
    Eurovox AM/FM Radio/CD Player, far as i know the one that it came with.
    STEALTHY™'s Avatar
    Jan 2005
    Oh ohk, no solution then. I know some had a beep if you leave the face on the deck after switching the car off.
    cheers sexy
    kart_racer is offline Races karts
    VT Acclaim 5M
    May 2008
    Could be your airbag light/warning but that particular bulb is blown? Airbag warning will chime every time the car is started.
    Anyone with a Tech 2 should be able to read what the warning is for.
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    oil pressure warning (low) check globe's on startup to see if all light up.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    Vx Executive
    Jun 2009
    Quote Originally Posted by burnz View Post
    oil light lights up same as all the rest as normal when first starting a car but all go off before the beeping starts so none can be related to it.
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by negh_var View Post
    after the car starts the warning light goe's off automaticly, after a ferther 15 second's then it will report the true pressure.
    if low a series of beep's.
    note: on some models their are two senders in one unit.
    1 for the gauge/dash light
    2 for the monitoring computer
    Powered By Garrett
    VT 2
    Nov 2008
    Airbag sensor sets of a series of beeps. Thats the only one I know - replaced my Drivers seat (which had a 'bag) with an SS seat which did not. You CANNOT disable the beeps, without disabling the entire airbag system..........
    Oh - the airbag warning beeps are 3 beeps of rising tone in sequence, 3 times. Maybe just your airbag light is stuffed and you have a loose connection in the chair.
    AAARRRGGHH
    MikesCalais's Avatar
    MikesCalais is offline Trust me, I'm a Doctor
    VE Calais V International
    Dec 2008
    my car goes beep beep beep, the time goes beep beep beep, the world goes beep beep beep
    I know it doesnt help, but I was just listening to that song and it seems really relevant (car goes beep beep beep + theres 9 beeps right there )
    I was gonna suggest it could have been your cd player but if its the stock one then no
    What about the low petrol warning? I know it sounds silly but commodores have a big problem with their fuel gauges, maybe it senses theres low petrol and then the needle moves back up?
    Probably not it, but a suggestion
    Vx Executive
    Jun 2009
    Default Called Holden...
    Well called holden but the guy said it could be a number of things so bringing it to the garage as they can read the computer from there and see what the exact issue is. There's a few other minor things so might as well get them all sorted out now.
    Thanks for the help guys.
  1. VS Warning Beeps
    By DocBald in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2009, 11:41 PM
  2. Beeps when i slow down
    By iplzher in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2006, 12:43 AM
  3. Anyone know what the 9 beeps mean on startup?
    By Gravy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2005, 09:51 PM
  4. Beeps VR V8 Calais
    By jale in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2004, 02:13 AM
  5. It Beeps At Me?
    By Robbie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-03-2004, 12:06 PM
