Results 1 to 3 of 3
Thread: HELP: VT SS Engine light and oil light coming on
    VT SS 5.7Ltr
    Jul 2009
    Default HELP: VT SS Engine light and oil light coming on
    Hey,
    I have a 2000 VT SS II 5.7ltr it has aboout 211 000Ks on it when i turn the car on the engine light stays on constantly has a machanic check it out and says it might just be the oil sensor, every now and then around a corner or a set of lights it will beep 4 times and flash the oil light then go back to the engine light being on, there is full oil in there and good engine compression.
    I did the oil and filter change at 210 000Ks and turned it back on and engine like flashed on then off and then stayed on constant again.
    Any ideas ??? Thanks
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The oil pressure sensor is a common problem. I've replaced mine but it needs to be replaced again, but they are quite expensive so it will have to wait a while.
    MY RIDE
    VX Series 2
    Dec 2008
    Canterbury Area, Sydney
    Check the wire to the Oil pressue sender switch is'nt loose. Check your oil pressure with a master guage too. Your oil pump might be on its way out
    If its not working, you're not hitting it hard enough.
  1. engine computer light keeps coming on
    By carpetsnake in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2008, 02:17 PM
  2. Check engine light keeps coming on
    By chromic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2008, 08:58 PM
  3. Engine light coming on.
    By Nanos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-06-2008, 07:30 PM
  4. Engine check light not coming on!!
    By bladerunnerkim in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2007, 11:03 PM
  5. Engine Light keeps coming on
    By Naughty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-08-2006, 03:08 PM
