Results 1 to 8 of 8
Thread: VT vacuum supply to heater tap
    VY one tonner / gen3 / 6speed
    Jan 2009
    just left of hell
    Default VT vacuum supply to heater tap
    Wife's Vt V6 had a problem last year when heater tap would not turn off, due to no vacuum at the diaphragm. Against my better judgment I pulled the dash apart and couldn't find anything wrong. Followed all the hoses, the controls were all working perfectly, operating the little plunger bizzo which supplies vacuum to the hose, which was supplying vacuum as it should all the way to the tap.
    Strange I thought, put it all back together knowing in the back of my mind that it would come back to haunt me, and 10 months later...it has!! No vacuum at the heater tap.
    I would rather crawl across broken glass face down with my fly open than pull that dash apart again.
    I suspect the vacuum hose to the tap is pinched/squashed somewhere under the dash, has anyone ever had this one before?? All the other vacuum operated functions work perfectly.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Does the heater tap turn off and on if you operate it by hand at the heater tap? Maybe the tap has seized.
    MY RIDE
    VT spac super6
    Nov 2008
    Riverton sa
    the heater tap is in the engine bay mate... driver side of engine just below the brake master cylinder
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    VX
    May 2009
    + 1 Replace Heater tap unit about $30.. i did mine when i did the heater core, i replaced the pipes also while i was in there
    Jan 2009
    just left of hell
    Heater tap works fine, there is no vacuum getting to it when control turned to cold.
    Looks like a visit inside the dash again....
    vs s ute series 2
    Sep 2007
    vn calais series 1 3.8
    Sep 2009
    hi i had the same problem and in the end the it was a blocked air line .
    try to blow your air lines clear
    but make shure you have the air line unpluged on both ends to save braking things
    then blow the lines clean with a air compresser
    in my case it was it the heater tap metal air pipe
    so i just replased the heater tap
  1. VP Calais Heater vacuum
    By vsuterus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2011, 11:58 AM
  2. snapped vacuum hose for heater controls....
    By roon_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2009, 03:51 PM
  3. Removing the Vacuum Block from the heater controls?
    By ProggerPete in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-02-2006, 06:41 PM
  4. VP Heater Vacuum
    By syncope in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2005, 07:43 PM
  5. No Vacuum at the heater tap
    By electradaz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2004, 02:27 AM
