Hey guys,
I've ditched the 20" SSA Chrome wheels for some factory 18" rims. I'm wanting to lower it about 30mm nothing too low, but just tastefully as at present it looks like its up on stilts!
Is there anything I should look out for? ie: Spring Make? Height level? Camber etc?
Also, how easy is it to fit your own springs?
Thanks,
Smokin!
id go king spring superlows
the back are easy as just take wheel off make sure hand brakes off undo shock and pull out and replace
but the fronts you need a spring compressor and a bit more time theres a whole thread on how to do it
Hey guys I was just wondering if some1 could tell me how much lower my vt would be with super super lows
if you have stock everything atm the tyre will be just above the wheel well
Thanx and will it be legal plus everything stock wat else will I need
