I may have to replace instrument cluster in 99vt exec, wondering as shows lpg light when on gas, do all clusters have that light in background or is mine one that is specific for dual fuel?
Secondly, replacing cluster due to oddoerr being displayed, believing this is internal fault with the instrument cluster, could there be any external reasons for getting this error, ecu shows a 12 no faults found...stereo been removed some cut wires?
Not sure my original calais cluster had the LPG on it as does the statesman one that I swapped it with and neither had factory lpg. My gauges change also depending on whether it's on gas or petrol.
Thanks hey!!
Yes all clusters have the LPG lamp, it is "activated" via Tech 2 on the factory LPG models. Some of the aftermarket dial faces don't have LPG printed on them, whereas all the standard factory ones do.
Dunno 'bout the error but.
Km's are stored in the cluster so id say it is a cluster fault![]()
Some after market LPG kits have a lamp from the kit that you put into the back of the cluster where the lpg symbol is so it lights up the LPG on the cluster
