Results 1 to 9 of 9
Thread: computers causing different cranking
    vt executive dual fuel
    Jul 2009
    Default computers causing different cranking
    I'm trying to get my vt started, have spark and fuel but not firing, what I've done now is change the ecu computer. The original was allowing continual cranking, now when changed to this new unit I only get motor cranking maybe 2 turns then stops, why would they be cranking different when all I've done is switch between the two?
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    VX Executive S2
    May 2006
    Frankston South Vic
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    plug ur original ecu, then check your error codes, as lout said, its sounds like the immobiliser isnt being switched off on ur old ecu.
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    the PCM needs to be linked to the BCM or you will never get it going.
    Rob
    Jul 2009
    Jul 2009
    Doctor Bob's Avatar
    May 2004
    the linking needs to be done using a Tech2
    why are you changing the PCM anyway?
    Rob
    Jul 2009
    I'm changing the Ecu (computer) because I've got spark, fuel and cranking and compression but not firing, have swapped dfi module, coils, crank angle sensor, checked fuses, searched for bad connection, been all over things and now figure try ecu. Got it from wreckers and was told to simply plug it in and turn key!!@ Dada only cranks two turns and stops. Been in and out of holden dealers and they're no help, trying to fix problem myself by elimination...I've swapped original memcal into this new ecu and not made any difference.
  1. cranking not starting
    By bmcleod in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-07-2009, 08:43 PM
  2. Slow cranking VT
    By SLAF in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-07-2009, 08:41 AM
  3. cranking problems
    By jimbojones889 in forum General
    Last Post: 09-07-2009, 10:46 AM
  4. Cranking but Not Firing
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2007, 04:25 PM
  5. VR Slow cranking
    By CrazyDayz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 11:02 PM
