Results 1 to 7 of 7
Thread: Window scratches
    VX Berlina Wagon
    Oct 2007
    Default Window scratches
    gday fellas, i was putting up my window the other day and i could hear a slight scratching noise as it almost reached the top, then i looked at the glass and there is a couple of slight scratches....i tried to look to see if there was anything stuck in the rubber but i couldnt see anything...does anybody know what it could be? is this a common problem?
    mwb235 Guest
    Quote Originally Posted by King_berald View Post
    My August 98 VT Calais was doing this too. It is a known fault in VT's particulalrly the early series one models.
    Amazingly if you buy a new set of chrome window strips from Holden Spare Parts, they still have these "unmodified" clips which cause the scratches.
    This attachment might help you, it worked for me (i replaced all my glass, did this mod, haven't got any scratches since).
    The other possibility - grains of sand stuck in the felt edging that presses against the glass. Take off the window strips, clean them with a brush & soapy water, and refit.
    Attached Thumbnails Attached Thumbnails Window scratches-vt-vx-door-glass-scratched.jpg
    VX Berlina Wagon
    Oct 2007
    Quote Originally Posted by mwb235 View Post
    thanks man...but mines an 01 berlina.....doesnt that mean that mine would already have them? also..one of the marks are on the inside...and the other is on the outside...
    mwb235 Guest
    According to that page i posted (i won't say where it came from) even my Aug 98 model shouldn't have them. All VT/VX and even VY's i've checked this out on at wreckers have the "unmodded" clips, i don't know why.
    Anyway it may not be the cause of your problem - it would be scratches in three places only (outside, each end and in the middle) so if you have one on the inside, i got no idea.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Take the window strips off and give them a clean. You will be surprised at the amount of crap that builds up on them.
    VX Berlina Wagon
    Oct 2007
    Quote Originally Posted by Dayvo View Post
    is there any easy way of doing that without pulling off the door trim? and without ruining them?
    mwb235 Guest
    The back doors have one phillips screw at the end closest to the front door, remove that (under a small black flap), then gently lift up the seal starting from either end. Don't use too much force or you might bend them. Refit by carefully lining up the screwholes at the front (so you can get the screw in etc) then press down.
    For the front doors, the strips can be got off with the mirrors left on (which need the door trims removed to remove mirrors), although it is slightly easier without the mirrors but not necessary. Same as the backs, but the one phillips head screw is at the end closest to the back doors. When refitting, carefully slide the front end under the mirror seal first (make sure the seal doesn't catch/bend) then press down.
  1. How to fix those little scratches
    By Dayvo in forum Holden Commodore How-To's
    Last Post: 10-05-2011, 10:42 PM
  2. window scratches made while winding window
    By callum_88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-07-2009, 08:30 PM
  3. VL scratches, help plz :(
    By john_mete in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-02-2009, 09:30 PM
  4. Scratches
    By jamiekratin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-09-2005, 07:59 PM
  5. getting rid of scratches
    By Bek31 in forum General
    Last Post: 25-08-2004, 10:14 PM
