Results 1 to 9 of 9
Thread: VT heater stopped working??
    pl0x is offline Pl0x
    VT Wagon V6
    Jul 2009
    NZ
    Default VT heater stopped working??
    On my way to work this morning heater was working fine, then suddenly it stopped and went cold?
    then got to work and some steam was coming out around the left side of the radiator didnt have time to remove any covers or anything to have a look
    was going to wait till it cools and check water levels etc
    Edit: Just checked coolant level and from i can tell is fine, (assuming the holes in the dipstick are meant to be how to read it)
    Temp gauge was just under half the whole time
    Any ideas??
    wetwork65's Avatar
    wetwork65 is offline A wet business
    VY Berlina V8 & VZ Adventra LX8
    Mar 2006
    With the goblins in South West WA
    Air trapped in cooling system? Try bleeding the air out?
    Thinking about this one - the temp gauge would be swinging around if there was much air in the system.
    How about the thermostat?
    Then things get harder and more expensive!
    How is the old (beautiful) country? I'm starting to miss the place since moving here some time ago. This mining lark is a bastard - can't get paid the same in NZ (or Sydney).
    VT Wagon V6
    Jul 2009
    NZ
    i went out at lunch yesterday and filled up the radaitor as i couldnt see any water in there, took 5 750ml pump bottles before the water/coolant started leaking onto the ground.
    Did a headgasket check but was fine so was lucky in that sense
    Got a new radaitor on the way as i think i cracked it?
    Anyone got any ideas why?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The side tanks on the radiator are made of plastic and therefore they deteriorate after years of use.
    MY RIDE
    VT Wagon V6
    Jul 2009
    NZ
    Quote Originally Posted by accentstencil View Post
    mhm looked like it was leaking from the middle so could this still be the case? i didnt check wear it was leaking from so it could have dribbled down something to the middle then dropd, it was sreaming from one of the sides
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by pl0x View Post
    The radiator core is made of aluminium and if you do not use the correct coolant and in the correct proportion it will greatly reduce the life of the radiator as well. That is why it is very important to use a coolant which meets the specifications of your engine. It is not cheap but it will save you money in the long run.
    MY RIDE
    VT commodore v6
    Oct 2009
    Same deal with my VT wagon, (v6) temp needle was all over the place so changed the thermostat. that problem was solved, although still have problem of smelly heater and the windscreen fogging. all this and its not blowing hot air. do you think it could be the heater core? or maybe just the seals? i cannot find any coolant leaking but i can hear the bubbling under the dash and the radiator needs topping up from time to time.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Quote Originally Posted by Philywilly View Post
    sounds like heater core. mine didnt leak either unless wen i had the aircon on which it then leaked from the drain pipe near the gearbox.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VT commodore v6
    Oct 2009
    Darn, so out comes the dash then... Cheers for your help.
  1. aerial stopped working????
    By clubby1996 in forum General
    Last Post: 13-04-2009, 01:05 PM
  2. Subs stopped working??
    By randomhero365 in forum Car Audio
    Last Post: 19-02-2009, 07:58 PM
  3. My key stopped working.. :(
    By Howks in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-07-2008, 11:52 PM
  4. VN speedo stopped working.
    By VN_SS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2007, 12:32 AM
  5. Odometer stopped working in VP
    By jabbavx in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-03-2006, 05:44 PM
