Results 1 to 10 of 10
Thread: Vx gts
    Vt clubby R8
    Sep 2007
    Mt Eliza, VIC
    Default Vx gts
    hi im looking at updating my vs clubbys to a vx gts i have been researching them a bit and they say they come with a shift light does anybody know where this is located. is it the hsv logo that lights or something. Also do they go much better than a vx clubby? also is it true they have 3:9 diff gears standard. thanks
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    The GTS version of a VX was called the SV300, a sort of senator/clusport hybrid.
    The GTS name was used in the VT11 (the first of the 300kw GTS with the C4B engine) and then again in the VY where it was available in man and auto.
    The C4b engine has a camshaft problem, although most would have repleced the cam by now.
    The std rear end is 3.9 in the manuals .
    Cheers Col.
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Quote Originally Posted by Surfwagon View Post
    Cheers Col.
    There was also a GTS(hence you can buy VX GTS wheels etc), the SV 300 was basically a senator with the GTS running gear.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    BLOWN VX CLUBSPORT R8
    Apr 2009
    Yes they DO make a VX GTS, yes they are 3.91's, shiftlight is on the lefthand side of dash under temp gauge i think, VX GTS is rarer than a VX Clubby But the R8 is on about par i think, both absoulutely awsome cars
    BLOWN, CAMMED & SLAMMED R8 :twisted:
    Real Cars Dont Power The Front Wheels, They Lift Them
    Y-Series Senator Signature
    Jan 2006
    Willall Racing
    Quote Originally Posted by adzy_5l View Post
    The GTS has a factory head and cam package, and are mafless tuned as std. They do go much better than a stock clubby. 300kw at the fly rated.
    carless for now
    Feb 2007
    perth,Western Australia
    the sv300 is different more like a senator.the gts and the 300 both have the c4b 300kw engine and factory maffless and 3.9's.you can get the gts for pretty cheap now i saw a few around the 27k mark
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Cheers Col.
    The problem with the C4B engine was the valve springs (which break) not the camshaft.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    There were a few guys on the LS1 forum who reported then the rear lobes on the cam were all broken and chipped when they replaced the cams and only seem to affect the C4B engine.
    Here is one of the threads, there are a few.
    Australian LS1 and Holden Forums
    Also found this in relation to how many were made.
    They made 100 VTII's (27Red and 73 Black) All had identical interiors with the only option being a sunroof.
    They made a couple of hundred VX GTS's, however unlike the originals, the VX's didn't have leather standard. They also had problems with the 19" wheels and tyre wear, so the early VX GTS's came with a shadow-chrome version of the then R8 wheel. Once HSV changed over to the PZERO for 19's all VX owners were offered an upgrade package to the 19" rim/tyre combo.
    The VX2 was nameplated the SV300, and they went to back to a limited build again. This car used a silver version of the VTII Wheel (back to 18") but they didn't sell very well and there were brand new ones selling in Brisbane months after the release for under $80k.
    (They also made a limited edition (25 I believe) Senator300 which was basically a GTS with a senator interior).
    The VY GTS was limited to 100 vehicles and was the first 4 door GTS available in an Automatic Transmission.
    The VYII GTS was an order only vehicle and it came with the Ohlins adjustable suspension.
    Cheers Col.
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
    Quote Originally Posted by BlackVXGTS View Post
    the cam was a problem as well
    they are very weak and the lobes wear down
    cheers GM
    Vt clubby R8
    Sep 2007
    Mt Eliza, VIC
    thanks for that guys time to sell my clubby now
