OK for all you guys that know i was putting a VY IRS into my VT series2 ,
Finnished it today was not that difficult .Everthing bolted up perfect ,but did have to get a VY tail sharft as the VT one is different ,also my exhaust will need replacing as it now hits one of the brakets ,just a little has about 2 min clearance, with car running it just hits it ,other than that everything is good .
I did this by my self so if anyone want to do it you can give yourself 2 days just taking your time ,and some good jacks to help lift it into the right spot,,hope this helps you make up your mind if you want to do it ...![]()
Hope you didn't have a sports system ?. If you didn't good time to get one.
Did you snap any pic's of your installation ?.
did you get the cradle aligned ?
cheers GM
That's ok, pretty hard to do 2 things at once.
Some have said the VT Series 2 onwards was different in many ways to the VT Series 1, but i just thought they were bullshitting. Now to find a VY irs and see what type of price. I should price a 4 point camber toe kit also to compare prices.
need some pics of the install =P
