thinking of dropping a T56 into my VT II S....i got a mate who says when i do it he can hook me up pretty good....would it b a good idea??
t56 are the shit hands down but it will be a big job but sooooooooooooooooo worth it lol
6 cyl or V8? T56 is a ton stronger than the t5 that is for sure.
Reaper
his got a s pack vs so it would be a 6.
thankz alot guys
i know it would b a big job and a fair bit fo to and change...but all in all if its worth it i would do it....so if i will have a low change of braking it..(knowing its only hooked up to a V6) and the fact of having a 6 spd i will change it ova......but from the performance side of things....and the diff ratios....will she b any diff on take off and in general acceleration
haha oh ok fair enough thankz
well then ill do my reaserch and find the best suit ratios and diff that best suits it...if you know anything thats good for a T56 on a v6, i would love to hear it
You'd be wanting a diff ratio change too I'd imagine, the T56 has quite low ratios - eg 1st gear is 2.66:1.
DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
Originally Posted by Reaper
yeh looks like its the way to go
3.9's are a t56 would be fun.did the t56 come out in a lot of 5ltrs i though it was for 6speed ls1's??
You'd want at least 3.9, probably 4.11 even. I have a T56 + 3.7's, and if I had a V6 behind it, it would be rather dull.
The 6 speeds never came out on a 5L. They were the box of choice on the VR/S Stroker motor HSVs, aswell as the LS1.
I don't know the electrical side of things, but mechanical, all you will need is a bellhousing, and maybe different input shaft (not sure on V6, as mine is a 5L). Tailshaft will be the same if your car is already manual.
Also have T56 with 3.73s, was advised not to have anything less than 3.9s, 4.11s would be best. So next time the diff goes in for a freshen up, i'll be changing mine.
Originally Posted by davway
so will it really b worth me doing it in the long run, if i get the right diff and so on....in the
end its still behind a V6. compared to the T5 in it now...would the T56 with bellhousing and different diff b better?
Of course it will be better. I not sure its completely needed tho....
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
Any floor mods needed for a T56/VN/P 5 litre at all?? What about input shaft mods(or just a T56 clutch plate?)?? And a Dellow housings needed?
T5 feels like it's made of glass as it is...
