Results 1 to 5 of 5
Thread: Engine Oil Recommended
    VSII VXII EXECUTIVE
    Jul 2009
    Default Engine Oil Recommended
    Just bought a VXII V6 auto. Already have a VSII V6 auto. Holden recommends different grades of oil for each. Why? What engine oil should I use?
    VL V8 & supercharged VX
    Nov 2006
    western vic
    VSII VXII EXECUTIVE
    Jul 2009
    Default Engine oil recommended
    Thanks for your reply. But why does the manual recommend 10/40 for a VXII but 20/50 for a VSII? Also, the manual states the VSII takes 4.3 litres of engine oil while the VXII takes 4.8 litres. They're both ECOTECH 3.8 engines.
    VX S
    May 2009
    Even though their the same engine, the vx is better machined so that its tolerances are smaller than the vs thus only requiring the thinner, more modern oil. Thickness of oil also depends on how many k's you've done. The older the engine, the thicker the oil should be so the engine lasts longer. With the size, could be that the vs ran a larger sump or longer lines than the vx.
    VZ SV6
    Oct 2008
    Newcastle NSW
    The original rating for both engines is ISLAC GF-3 which is 10W-30, but probably too thin for Australian temps (unless you live in a snow area) plus also the early VS had oil consumption problems, so 20W-50 was used more commonly (and recommended by Holden as by the time the VS was released it had 20-50 written in the handbook).
    Also consider the kms and age of these engines by now, so a slightly thicker oil is probably warranted...
  1. Recommended upgrades
    By DUK13Y in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-12-2007, 11:59 AM
  2. Recommended Workshops - QLD
    By CMI83 in forum General
    Last Post: 11-04-2006, 03:03 AM
  3. Recommended Wreckers
    By VNwagMan in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2005, 01:29 PM
  4. Recommended Carby
    By mza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-04-2004, 09:25 AM
