Clutch slipping problems - i replaced slave & master cylinders - still not engaging - going further in to throw out bearing & return springs. I disconnected gear stick linkages, to find leakage on around trunnion rod. Is this a leaking seal? If so would this cause me to slip & miss not enage in any gears? do i proceed further into gearbox? Please help thankyou.
