Results 1 to 6 of 6
Thread: VT going crazy...
    Kikki's Avatar
    Kikki is offline WA Cruise Moderator
    08 VE SSV Sportswagon & 98 VT Berlina Wagon
    Aug 2007
    Eaton, WA
    Default VT going crazy...
    I just started my car and got beeping, air bag light was on and the red light that's above the mode button was flashing really fast.
    Turned the car off and started it again and it was back to normal, then on the way home it did the same thing.
    Any ideas what it could be and what's required to repair it? BCM maybe?
    VT Berlina 2000
    Jul 2009
    Geelong, Victoria
    hmm.. never had that problem with mine, might be a good idea to get a quick diagnostic test? i keep an eye on mine constantly just had to get an aldl cable and some software, but some places will do it for you. Rudding a full diagnostic usualy tells you many of the problems currently with the car so have a look into it
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The clock spring behind the steering wheel has most likely shit the tin.
    Visit my Facebook page
    VT Executive S2
    Aug 2008
    Melbourne Victoria
    Mine did it to me the other day also, hasn't done it since though. Would love to know what it means.
    kart_racer is offline Races karts
    VT Acclaim 5M
    May 2008
    Could be ABS module - will throw up the same symptoms if failing.
    Pull the abs fuses and see if it goes away.
    D-Man's Avatar
    D-Man is offline All over it...
    99 VT Calais II v6
    Aug 2008
    Melton, Victoria
    same thing in mine,
    my airbag light and engine and oil light came on, had a mechanic check the engine and he said all was okay.. started the car and they turned on again, took it to a friend who had the computer for it, he plugged it in reset the computer and havent had an issue yet. (18 months or so ago)
  1. rev crazy
    By 5ivespeed in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2009, 06:14 PM
  2. VZ Sv6 ute goes crazy
    By mattieschwarz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-05-2007, 01:11 AM
  3. CRAZY CRAZY ABABS!!! nutters, seriously
    By MikeVXSS in forum The Pub
    Last Post: 02-12-2006, 06:46 PM
  4. Crazy Cat
    By HoZy in forum Jokes/Humour
    Last Post: 02-06-2006, 11:23 AM
  5. Help! Im going crazy!
    By cacaman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2006, 02:05 PM
