Results 1 to 8 of 8
Thread: What is this warning light??
    VX II Calais
    May 2009
    West Sydney
    Default What is this warning light??
    Hi all
    Got in the car this morning and this light come on, its a circle with a exclamation mark in the centre and lines going around the circle. i thought it was the handbrake at first then realised its a differnt light... When i applied the brake it went away for a few seconds then come back. eventually went after a few mins. Is this low brake fluid or brake fail??
    Any ideas?
    Cheers Frank
    5.7L VX II Calais ,Tungsten,Vy SS Rims,Full cream leather,Twin,2.5" Redback Catback,Pacemaker 4 to 1's,5% Tint,Chromed Grille
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It is the handbrake/brake fail warning light. If it lights up when the handbrake is off then it indicates that there is a problem with the brakes. Check fluid level and if that is OK, get your brakes checked.
    MY RIDE
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Sounds like the brake/ parker light fail light?
    Maybe one of your globes are blown or on its way out
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Ozzie View Post
    The rear lights fail symbol is a part circle with with a light bulb in it.
    Attached Thumbnails Attached Thumbnails What is this warning light??-rear-light-fail.jpg
    MY RIDE
    VX II Calais
    May 2009
    West Sydney
    thats the one! but it went off when the brake was pressed then went away eventually...
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by mrvx2 View Post
    Then you probably have a dodgy tail light globe or numberplate globe or loose connection.
    MY RIDE
    VX Calais 5.7
    Aug 2009
    I took my car in to get a service and ever since i got it back this light has come on if i hold the brake on for 3-5 seconds or more and then it goes away as soon as i release the brake. any ideas? my tail light also fills up with water on occasion so im thinking the two are linked but as yeat haven't been able to fix the light
    wetwork65's Avatar
    wetwork65 is offline A wet business
    VY Berlina V8 & VZ Adventra LX8
    Mar 2006
    With the goblins in South West WA
    If there is no blown bulb and the service place disconnected the battery you will get this warning light coming up - the system has to be reset to learn what the current bulb resistances are. happens only on Calais (and LX Adventra ).
    I can't find the instructions to reset. Maybe search?
  1. Alternator Warning Light & ABS OFF Light
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2007, 10:10 PM
  2. Tail light warning light
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-08-2006, 06:27 PM
  3. Tail light Warning light
    By G4orce in forum Electrical Wiring / Questions
    Last Post: 26-07-2006, 08:15 AM
  4. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
  5. Dash Light Warning Light
    By Bongo in forum Electrical Wiring / Questions
    Last Post: 07-10-2005, 08:17 PM
