Results 1 to 11 of 11
Thread: supercharge motor
    vx-acclaims2
    Oct 2006
    Arrow supercharge motor
    I have a vx acclaim ser2, I bought L67 heads, bold on supercharge, manifold, fuel rails, injectors,ecu,harmonic balancer and fuel pump, to put in, no upgrade on the boost.I've been told that it might blow up so i havent put it in the car yet waiting to get a gasket kit. just wondering will it run ok with a standard motor,
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I don't know much about the supercharged engines but I believe they have stronger internal parts.
    MY RIDE
    vx supercharged
    Feb 2009
    D-Man's Avatar
    D-Man is offline All over it...
    99 VT Calais II v6
    Aug 2008
    Melton, Victoria
    No no problems about setting up a charger on stock motor you just have to be weary of the psi you want... stock engine wont be able to widthstand as much as a worked motor..
    check out the raptor section on the forum for a little more info if you need re stock motors and chargers etc.
    maybe ask them a couple questions on what they reccomend for setting up on a stock motor.
    cheers,
    Quote Originally Posted by danja View Post
    PS. All girls are the devil. It's science.
    vx-acclaims2
    Oct 2006
    I just spoke to the guys at yella terra they have gaskets to lower the compression of the engine, i think its cheaper then to bore the heads i think,
    VT spac super6
    Nov 2008
    Riverton sa
    decomp plates are bad news man honestly
    majority of people just have troubles with them non stop
    stock boost will MAX 7psi average 6psi tops
    stock bottom end should take it no problems just make sure you have decent fuel or youll start melting pistons
    itll need a tune afterwards aswell..
    if you were that worried about it you wouldnt have been messing with supercharging a na motor
    vx-acclaims2
    Oct 2006
    carless for now
    Feb 2007
    perth,Western Australia
    BIG-EV's Avatar
    BIG-EV is offline Project VT (In Progress)
    2000 VTII Executive 3.8L Supercharged V6 Wagon
    Oct 2008
    Mango Hill QLD
    hey man i did that same and im running 11 pounds atm non intercooled on a stock ecotec bottom end and its having no dramas. im about to get the bottom end rebuilt anyways with acl gear and forged pistons and H-beam rods. kicks ass atm though. plan will be to get 21 pounds out of this charger buy Christmas.. ho ho ho
    redcv6's Avatar
    redcv6 is offline supercharged intercooled
    vy ss ute, diesel landcruiser 100s, hq panel van
    Aug 2006
    Ringwood
    the l67 has ceramic coated pistons and a few other things to strengthen it. will you put added pressure on your l36 bottom end, yes, will it hold up on standard psi , yes unles you drive like a F*ckwit. if i were you i would sell the kit you have, and buy a full l67 motor and drop it in, im guessing you paid about $2gs for that gear, so the l67 shouldnt cost too much on top of that.
    VS Calais & vh sl
    Dec 2006
    deception bay
    Quote Originally Posted by redcv6 View Post
    why bother doing that a stock ecotec will handle 10psi fine and if your that worried about it give the short motor a reco with lower comp pistons.
  1. vx supercharge
    By Vs-AclaimII in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-07-2009, 03:04 PM
  2. Supercharge VL?
    By WillysWalky in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-01-2009, 10:34 AM
  3. Supercharge LPG
    By feistl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2005, 03:35 PM
  4. Supercharge hot 3.3?
    By DrewOfNZ in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-05-2005, 12:46 PM
  5. Vr V6 Motor Take A Vt Supercharge Kit With Al Part
    By Supercharged_up in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-12-2003, 07:46 PM
