Hello everyone.
I am currently in a position where I need to upgrade my brakes.
I would prefer something that came out factory on a Commodore or HSV.
After doing some research I have discovered that HSVs run a Harrop calliper system but this is too much for what I need.
Unfortunately I cannot determine the specifications of SS Commodores where I believe they would run a 330mm front disk.
Harrop sells a kit that puts 330mm front disks on with a special calliper bracket but seems to run the PBR callipers that are standard on Commodores. No information is given if they do actually use the PBR Calliper.
My question is do SS Commodores have 330mm front disks using the standard PBR calliper with a calliper bracket that is like in the Harrop upgrade kit?
Has anyone successfully upgraded their brakes using such a bracket with 330mm disks and larger pads?
JCCC NSW Member
Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
Just Commodores NSW Chapter. Join in for a cruise some time!
Click here for more info
Would you consider the VE upgrade?
VE twin pot calipers
Curved slot and dimpled rotors 322mm
New braided lines
New pads
New mounting bolts and brackets
New brake fluid
$695 for the VX.
Yes I would.
Do you sell these kits yourself?
JCCC NSW Member
Would that be the same price for a VT??
NAAF, PM sent!
JCCC NSW Member
Are these what the VE run as standard?
If they are then its easy for replacements then.
JCCC NSW Member
The pads and calipers are yes, but the rotors are developed for each model as a retro fit. The rotors that fit the VX aren't the same ones that go on a VE, but they are always going to be readily available.
arent the vt-vz ss brakes like the exec's??
All VT-VZ brakes V6 and V8 are the same. The only difference is the HSV upgrade which was optional.
thats what i thought.and hsv's are pbr kits you could find a r8 kit used for pretty cheap
what have you got for a vs v8 ute mate?
Front only. The rears are plenty good enough. As another member keeps saying, the rear brakes on the VT onwards are bigger than the Falcon turbos so they don't need upgrading.
