Page 1 of 2 12 LastLast
Results 1 to 25 of 43
Thread: URGENT HELP please motor reving to high
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Default URGENT HELP please motor reving to high
    hi ive just finished swapping my plenum and throttle body (Mace Engineering 69mm throttlebody) over to port and polish ones on my vx v6, when i turned the motor on it was all good reving normal around 900/1000 rpm when i gave it a few squirts of acceleration it started to rev up to 2800 rpm and stuck on and wouldn't rev down, i know the cable/petal isnt stuck can some one tell me whats going on please?
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    Could be IAC.
    Try this and it will tell you if anything is wrong.
    Checking error codes VT/VX
    Then find out what the code means and you will know whats wrong.
    Ben
    There is no such thing as stupid questions, Only stupid people.
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    thanks mate ill try it tomorrow
    TrEnNaVY's Avatar
    TrEnNaVY is offline Donating Member
    VY S V6
    Nov 2008
    dw about wot i said, obviously i didnt read it in great detail
    Quote Originally Posted by ChargedVX View Post
    I've got the missus opiniion but that doesn't count
    Forecast For Tonight Is Alcohol, Low Standards And Poor Decisions.
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by TrikkBen View Post
    Could be IAC.
    Ben
    just wondering where do i check the flashes from is there led's on the ECU????
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    In the VS the engine light flashes i dunno if its the same.
    Ben
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    hmmm can anyone tell me where to lool on a vx?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by MR_VX View Post
    The check engine light flashes.
    MY RIDE
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    sweet as ill try this all tomorrow thanks heaps fellas
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Could be IAC.
    Ben
    ok i just done it right, put the paper clip in terminals 5&6 turn to on/acc, it flashed 10 times, stoped (1 second) flashed once ( stop 1 second) flashed twice (stoped 1 second) flashed twice (stop 3-4 seconds) it keep repeted for about 7 times before i removed the paper clip can someone tell what code it stands for
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    doesn't sound like you read the flashes right. It flashes in tens and then one's.
    Read this one, it explains it there.
    Checking error codes VR/VS (Revised)
    Ben
    VX berlina
    Dec 2008
    Mate your problem is with the ECU because you've changed the air fuel mixture. you'll have to get it tuned
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    maybe i did read it wrong but i did read the same flashes about 7 times.
    i took the port and polished plenum and throttle body of and replaced it with the standard ones and it reved normally all good. so i put just the 69mm throttle body back on and it ran ruff around 2600 rpm so again i swaped it for the standard one and at first it ran shit house but the 2nd and 3rd time its all good again so its got me f**ked whats going on and not sure what to do with the aftermarket item i got
    Vx S pack m5
    Sep 2007
    keilor down, vic
    have you tried holding the revs at about 3000rpm for 30 seconds or so to reset the iac valve?
  15. #15
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    no i havent, didnt no i had to, does it actually work tho? ive pulled every thing back on and returned to stock for now but if these works ill put it all back on again
  16. #16
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    maybe the throttle position sensor is no good on the new throttlebody
  17. #17
    carless for now
    Feb 2007
    perth,Western Australia
    did ya try resetting the ecu.take the leads off the battery and starting again
  18. #18
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    i took the TPS & ACI sencers off my old throttle body (only done 65000kms) and used it on the enew one, but that didnt work i have 3 sets of both sencers wouldnt work with any, ill try disconnecting the battrey next time tho
  19. #19
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Had the same issue with my VX.
    Note the part called 'Adapter'.
    Make sure you replaced this correctly when you were putting the TPS into the new TB.
    This seems to be the issue in most cases.
    Give it a bash, good luck.
  20. #20
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    arrr i think your right mate i did notice it was smaller on the new throttle body conpaired to the old one! should it just pull out of the old one and push into the new one? thanks mate ill give it a try tomorrow!
  21. #21
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
  22. #22
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    yeah me to i think it will fix it tho thanks heaps mate
  23. #23
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
  24. #24
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    ive been busy with trying to build a house lol so ill try on saturday just incase it doesnt fix it that way ill have all day to try and fit it but ill let you all no
  25. #25
    MattyC's Avatar
    MattyC is offline Just cruisin bro
    VT Calais 5L
    Jun 2009
    When i was driving my VT II S and i stopped and parked it wouldnt rev under 2000 but then i turned the engine off and turned it back on and it was fine hah...
    never happened again...
    Third Ride: 2002 VX SS 5.7L V8
    Second Ride: 1998 VT Calais 5L V8
    First Ride: 1999 VT S Series II
  1. v8 reving high, stalling, overheating?
    By adamc11 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-04-2008, 11:11 PM
  2. reving out
    By aza64 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-09-2007, 11:29 PM
  3. Urgent!!!! - Shorting Starter Motor!!!
    By PaRaDoX in forum Electrical Wiring / Questions
    Last Post: 26-11-2006, 02:53 PM
  4. Engine Reving too High
    By SV-3800 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-06-2005, 02:01 PM
  5. Urgent Starter Motor Help Plz!
    By daggett in forum General
    Last Post: 24-06-2005, 06:17 PM
