Results 1 to 21 of 21
Thread: Front strut brace worthwhile?
    Slippy_Trippy is offline Unicorn Shepard
    1999 VT II Commodore Acclaim
    Jun 2009
    Melbourne, VIC
    Default Front strut brace worthwhile?
    I have read two different opinions on the worthwhilness of front strut braces on VTs, one being good and one being bad.
    What is the general concensus for a road car?
    -Slippy
    VY SV8 HBD---mmmm LS1
    Simon Champion! On The Volley Champion! Shootin Hoops Champion! Batting Champ Champion!
    Dec 2005
    Western Suburbs
    dont no bout vt but i had one on my old vr could feel i slight difference less body roll but you wont feel like your in a racecar or somthing.
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    yeah im looking at gettin one for my caprice too, for such a big heavy car it handles quite good but anything that improves that cant be bad
    Going where no late model stato/caprice has gone before.... GAME ON!!
    VZ SV6
    Aug 2008
    got one on the VZ and tis great better road holding especialy less sway during round-abouts
    vx s
    Sep 2008
    auckland nz
    just get it anything to make it stronger is got to be good.
    got one for my vx and im happy with it goes nice around corners now but then again i got it st away when got my car so not sure what it went like when pushing the limits before i got it
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Got one for the vy as the studs are already there to bolt straight in place. Cost 50-60 bucks from holden. Makes a little difference to handling but it's probably more cosmetic than anything. Pretty cheap add on though for 60 odd bux.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I'd be interested to hear the bad reason.
    A lot of cars come from the factory with strut braces now, so it is something that has filtered from the aftermarket into OEM production. It must be good.
    Visit my Facebook page
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    I believe they are good because the VT firewall was glued in, where the vs/vr firewall was welded in.
    So it would compensate for this lack of stiffness in this region, plus the extra weight in the VT making this worse.
    The most common 'bad reason' is that "they make no difference unless you are going about 100km/hr around a corner... on a racetrack". As most of you said, they will make at least a little bit of a difference, both cosmetically and performance wise, which is why I will be installing one for my VT soon.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    I wanted to put one in and the suspension joint reckons it weakens the pillar etc over time ? IS this correct ?
    VT Series 1 V6
    Jan 2008
    kart_racer is offline Races karts
    VT Acclaim 5M
    May 2008
    Quote Originally Posted by jazza15 View Post
    VR/VS was not welded in. They were glued in from the VN to save costs. The VT ended up suffering the same fate.
    Quote Originally Posted by vxcalais_01
    If anything, not having a strut brace allows flex between the strut tower and the body, and can cause it to crack away (has started to occur in my car). It would be reasonable to expect that a strut brace would prevent so much flexing and actually stop the cracking from occurring.
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    Quote Originally Posted by vxcalais_01 View Post
    I doubt that it weakens them. Check all the cars which have had them from brand new eg some model HSV's etc. These cars are sometimes driven hard and are now many years old, and I have never heard stories about the strut towers or the front suspension falling apart or cracking etc.
    I got mine from Holden for $48 (genuine + trade price) including the nuts and I can notice a slight difference on corners in my VZ Calais. But for $48, I thought why not for that price.
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I would tend to disagree with the "suspension joint" for the same reasons as the others have said; it adds stiffness to the strut towers and distributes the stress across the two, in effect bracing the upper front end, hence the name: Strut brace.
    Jun 2009
    Melbourne, VIC
    My local Holden dealer said VT's never came with them stock and could only find me ones to suit VY. Is the sizing different between that and the VT.
    If not where does one obtain a suitable one for the VT?
    -Slippy
  15. #15
    VT Series 1 V6
    Jan 2008
    The VT never came with them, hence there are no holes in the strut towers. I just bought a VY one from Holden for $47 and drilled the holes myself, only took a few minutes as I had the struts out at the time. Note that the brace does not come with bolts, you need to buy them separate. I went to bunnings and bought some high-tensile ones for $2 a pop. After market braces are also available from makers like whiteline and nolathane but cost a lot more than the holden ones.
    There is a how-to on this forum for installing the VY ones with photos. I would suggest that if you go the genuine holden route that you buy it from holden and not ebay, as they are all dearer on fleabay.
  16. #16
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by Not_An_Abba_Fan View Post
    I guess there is no bad reason. I couldn't see how it would make anything worse however the ones fitted to the VY were a function of the GM "Marketing engineering" department and any benifits were marginal - being kind.
    Not sure how they figure that one....
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  17. #17
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    A lot of the cars that come with the basic 2 point brace are just using it as one more selling point. The braces you buy on holdens from factory are about as useful as tits on a bull.
    Quote Originally Posted by HoldenOnn View Post
    Any change you have noticed is purely placebo. They really make no difference.
    Well said reap, almost every strut set-up i have seen on cars from the factory are just a marketing ploy. In fact any strut to strut set-up really will not do anything except lighten a back pocket. Yet to see evidence apart from the companies who make the product where it proves otherwise. It would be much more beneficial to do suspension correctly and have it all matched to the car(not just dump cheap shit springs in).
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
  18. #18
    HoldenOnn's Avatar
    May 2009
    Busselton, WA
    Quote Originally Posted by minux View Post
    Possibly so, but for $48 I thought why not
  19. #19
    Reaper's Avatar
    Aug 2004
    Actually on further reflection I take it back - it could do more damage than good. Any 2 point brace is really acting independently to the centre line geometry of the car. Assuming you had a piece of metal strong enough to move the shock tower, you would have it going from II in a straight line to // or \\ going around corners. Put simply you need to have to tie it to something that isn't going to move to be sure you are holding the strut towers in the appropriate position.
    Furthermore, if the shock tower was engineered to take a load in one direction and then gets an unexpected load in the other direction, things might not be pretty.
    Reaper
    Reapers Black VP SS
  20. #20
    minux's Avatar
    Feb 2005
    Well, at least your willing to say that lol. Some people on here they basically claim their car goes from a stocker to a V8 supercar
  21. #21
    Jun 2009
    Melbourne, VIC
    For the person asking negative reasons I'd seen, here they are.
  1. [SA] fs vr strut brace
    By thekid in forum Parts And Other Items For Sale
    Last Post: 17-01-2009, 08:11 PM
  2. SA - VS front strut brace
    By SKNOT9 in forum Parts And Other Items For Sale
    Last Post: 12-08-2008, 07:48 PM
  3. front & rear strut brace?
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2008, 10:19 PM
  4. Wtb Vr-vs Strut Brace....
    By sedate looking in forum Swap / Wanted to Buy / Trade
    Last Post: 17-03-2008, 05:12 PM
  5. How do i fit the strut brace??
    By buzurk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2006, 02:06 PM
