I was looking into getting a shift kit for my car but the cost of auto fluid is more than I can afford if I have to change it all.
Is it necessary to change it all over and if it isn't how much will I lose in the process.
-Slippy
Also while I am here, will the B&M kit cause the trans hold gears or only the Transgo?
-Slippy
Both kits will do the job but the transgo is more user friendly and complete. You will need around 6-8L of DexIII for the job if you are doing a flush or else 5L should do the trick
VYII Calais L67
i would recommened a shift kit anyday
