Results 1 to 14 of 14
Thread: brown crap in radiator
    Vx S pack m5
    Sep 2007
    keilor down, vic
    Default brown crap in radiator
    gday guys, A few months back I had a valley gasket go on my ecotec fixed it no worries and since then I have had no oil in my radiator, Took alook at my radiator today and there was a brown residue on the cap did not feel oily and when I put my finger down the filler neck there was brown stuff settled on the bottom. It also just looks like rusty water and has no oily feel to it. After I done the valley gasket I flushed out the radiator afew times. Where do you think this brown crap is coming from? seriously hope the valley gasket it no stuffed.
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    Could be crap that has broken loose and come through, just flush the radiator again and see if it comes back straight away, it may come back but not as bad, keep doing it till its clear for at least a week then run coolant and keep checking it till its all good.
    Vx S pack m5
    Sep 2007
    keilor down, vic
    shiftySLE's Avatar
    VH SLE, VZ Acclaim
    Jun 2009
    skruba is offline holden, honda, pitbulls
    vp executive
    Jun 2009
    parkes nsw
    Vx S pack m5
    Sep 2007
    keilor down, vic
    vn executive 6 cylinder
    Apr 2009
    Vx S pack m5
    Sep 2007
    keilor down, vic
    VT v6
    Jan 2009
    theres half a chance its from those little bricks that holden and some service centres tend to add to the coolant to "help lube the water pump seal" thats coming through, some of it may have settled and when u flushed the car its come unstuck from where-ever and come through the radiator...
    Financial Crisis? What crisis? Fuels cheap and so are parts. I dont see no crisis.
    Vx S pack m5
    Sep 2007
    keilor down, vic
    HAIGHIE is offline HAIGHIE
    VX Executive S2
    Jul 2009
    wollongong, NSW, AUS
    yer just flush it out again. take both hoses off the radiator off and put the garden hose in the bottom opening of the radiator then fill around it was a rag the just turn the hose on till the water coming out the top opening starts coming out clean, then put it all back together and run a flush thorught it. then dump the flush and redo the coolant
    VX Lumina S2
    Apr 2009
    Keniwck, Western Australia
    ive been having the brown crap coming through my radiator aswell..
    the mechanic i saw said it was oil in the coolant - meaning i had blown one or so heads..
    but recently my bf looked at it and said that it was rust because the idiot that last serviced the car only put water into my radiator.. i have flushed it a bit and then put some fresh coolant into it, still coming up with some brown crap..
    thanks for the help on the same problem... fingers crossed its only rust..
    vt v8 sv exec 044
    Oct 2008
    take it to get flushed propley at a radiator shop it will be the only way it gets cleaned propley
    Jul 2005
    Not a good sign. Could be intake manifold gaskets or head gaskets.
    Check you engine oil for water.
  1. Brown Jelly
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-03-2007, 05:41 PM
  2. brown slime in my radiator!
    By Fully in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2006, 06:05 PM
  3. Brown deposits inside radiator
    By Famine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2006, 06:49 PM
  4. brown vk
    By jamiekratin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-02-2006, 10:54 AM
  5. wats brown and sticky
    By SENATOR5.7 in forum Jokes/Humour
    Last Post: 24-04-2005, 02:05 AM
