Results 1 to 5 of 5
Thread: VX Random 3 monthly overheat
    Vx Commodore Lumina Wagon
    Jul 2009
    Default VX Random 3 monthly overheat
    Hi All, I'm only new here but have a question. I have a 3.8L VX. And starting about a year ago, it would just randomly "overheat" for no known reason. It has only done it 3 times ever, the temp gauge will read normal for about 20 mins then suddenly skyrocket to the computer going HOT HOT HOT in about 30 seconds. Only once when I have pulled up has there been any water run out from under the car. Once the car is restarted it is fine and doesn't do it again for a long time. I have tried replacing the thermostat and coolant; There is pressure in my hoses. The only thing I have found is that all three times the heater has been on to some degree. I would think this to be suggestive, however the heater gets used by my partner on almost a daily basis with no troubles. The vehicle has done many highway trips without a single issue and is a daily driver. Anyone who has experienced this before and/or has some suggestions it would be greatly appreciated.
    Cheers, Dave
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It happened to me once and it was due to a bad connection at the plug for the cooling fans, where they plug into the loom. Were your fans on at the time of overheating?
    MY RIDE
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by accentstencil View Post
    It happened to me once and it was due to a bad connection at the plug for the cooling fans, where they plug into the loom. Were you fans on at the time of overheating?
    Try this and if that fails, make sure that the cooling system's been air bled properly. Sorry but I have no other suggestions. I take it that the coolant reservoir is at its correct level and raddy full?
    Vx S pack m5
    Sep 2007
    keilor down, vic
    could also be that your cooling system is blocked doubt it though usally only happens to older cars.
    Jul 2009
    Hi Guys,
    Thanks for the responses. Yes my cooling fans are both on and functional. However I will check that again, better to be safe than sorry, right?
    I have also checked the coolant and radiator levels, and no probs there, also been bled to the best of my abilities.
    Holden suggests maybe an airlock in the heater assembly.
    Ah well, its due for new hoses and coolant. I think I shall just let them do their deeds and they will tell me if they come across anything while they are in there. Then it becomes a service warranty job
    Thanks for your help all. Dave.
  1. Best Oil after Overheat
    By Promotec in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2009, 06:28 PM
  2. Random Q....
    By Brin in forum The Pub
    Last Post: 15-01-2009, 03:51 AM
  3. VR Aircon Making Car Overheat
    By ViN3Y in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-10-2008, 03:00 PM
  4. engine overheat
    By doggie458 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2007, 10:31 PM
  5. minior overheat now and then
    By SlyVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2006, 07:18 PM
