Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By DVOLVO
Thread: please help regarding engine rev and stuck on
    VT series II
    Mar 2006
    Default *** HELP *** regarding engine rev and stuck on
    Hi guys,
    i'll start with the info of my car. VT V6, Executive, manual
    while i'm driving with the aircon on, rev the engine to about 3000ish rpm, changed gear and left it to neutral then, the rev stuck on or sometime stuck on and slowly dropped
    but, if the car stand still, i rev the engine and it never happen.
    can anyone help ?
    Thank in advance
    VT series II
    Mar 2006
    VT ll S Pack
    Jun 2009
    hey mate
    i have a similar sort of problem, i got a vt II spack manual, and yeh when taking out of gears she seems to hold revs, i would like some light on this too, im pretty sure it nothing to worry about tho, not gonna cause any damage
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    i have a vx manual to and she does the same thing holds revs abit when changing gears, i only noticed it when i got extractors and cat back exhaust
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    VT series II
    Mar 2006
    Quote Originally Posted by MR_VX View Post
    i also have extractors and full exhaust too, this could caused the problems then ?
    any help would be great
    Thanks in advance
    VU SS UTE / 5 Litre Volvo /Trusty Swift
    May 2008
    Penrith NSW
    I don't know if this is what is happening to your car but my Wife purchased a VX and the accelerator would stick now and again. Took it back for warranty 6 times they couldn't get it to do it said we were full of it . So I took a look at it( Long story Why it took me so long to look at it for her)But what was happening was where the Cable goes around the shock tower there is a insulator on it to stop the rubbing well that was getting caught with the twist of the motor under the cup on top of the tower.. Took off the Foam/insulation and its been sweet since..
    Hope this helps if not you others..
    Why is it called Alcoholics Anonymous when the first thing you do is stand up and say, 'My name is Ray, and I am an alcoholic'?
    VT ll S Pack
    Jun 2009
    yeh im the same with extractors a full exhaust, im thinking of getting a tune, might help the problem, but also going to look at what you said DVOLVO, could b the same simple little problem
    VT series II
    Mar 2006
    Quote Originally Posted by DVOLVO View Post
    Thanks for the info mate, i'll look at it tomorrow
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    2 Things I would do.
    1. Check the cable isn't sticking, maybe WD40 it and then send some oil on it too.
    2. Vacum hoses, make sure they are all connected properly and there a re no leaks.
    Other than that, unless you've been paying with your TPS or IAC recently, I'm out of ideas.
    Good luck
    vt exective
    Oct 2006
    Ok i had same problem found out it was ,i dont know the name but on the throttle body is the 2 sensors one is TPS and the other one that is right upthe top ,well i replaced that one and the problem was solved ,it controls the idle so i was told.$35.00 from holden all fixed ..,.
    VT series II
    Mar 2006
    Quote Originally Posted by glowworm View Post
    Awesome !! good to know, for $35.00 i'm gonna change it anyway and see what gonna happen.
    guys, any ideas what those parts called? i'm gonna ring Holden and order it.
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    FYI, there is only one sensor on the TB. The TPS, the other item you speak of is the IAC valve pictured below:
    As glowworm said, this controls the idle rpm by allowing more of less air to bypass the TB butterfly.
    If it is faulty and stuck open, the car will idle high. Also the car rpm will drop more slowly when you take your foot off the accelerator.
    If it's not the IAC, it could also me a faulty TPS, as the information the PCM gets from the TPS governs the IAC position.
    Good luck.
    VT series II
    Mar 2006
    I've talked to Holden's service adviser and he didn't think the problem caused by the IAC valve, he reckoned the TPS is faulty. also, IAC valve is gonna cost $120+ from Holden. what are you guys talking about $35 ??
    any more info guys ??
  1. Stuck CD
    By f1_power in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2010, 10:44 PM
  2. vl engine cuts out when driving. HELP IM STUCK
    By blue_vl in forum Electrical Wiring / Questions
    Last Post: 06-02-2009, 04:10 PM
  3. check engine warning, stuck in 2nd gear.
    By sp001in in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-03-2008, 12:31 PM
  4. still stuck in the 70s help me
    By mutant in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2006, 08:59 PM
  5. Stuck?????
    By liquidforce_134 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2004, 07:48 PM
