i got the gearbox and clutch out of a vy ss can someone plz tell me wot i need
you will need: pedals, slave cylinder, crossmember, manual wiring loom + ecu and also im pretty sure a new tailshaft, also if you didnt get them already, the boot and gear knob. im picking mine up tomorrow after being converted yay!
oh and i can tell you that the ecu + loom will not go into the vx from the vy. save yourself alot of headache and get the right gear for the model its going into. the box will fit, the tailshaft is different from a series 1 vx to a series 2 vx also (at least for the 6 anyway).
tailshaft the same cross member is as well
you will need
*loom vx manual
*M6 tune flashed in
*slave/master cylinder and line
*clutch pedal,you can cut you A4 one down
*spigot bearing
*gear boot/knob etc
*traction control button moved
thats about it i think
cheers GM
