Results 1 to 9 of 9
Thread: VX XU6 servicing problem
    HSV VT GTS
    Dec 2008
    Default VX XU6 servicing problem
    hey guys,
    Took my Mum's XU6 in to a Holden dealership for its 120,000 km service and all was fine, got home and left it in the driveway for 4 maybe 5 days before i drove it (As parents are overseas now) and when i started it up, it could barely hold an idol and was really rough.
    thought it might be something to do with the battery not charged so took it for a good long drive and brought it back. next day went out to start it again and same thing, can barely idol and rough. so took it for another drive and while sitting in macca's drive through, it coughed and spluttered and kicked the engine light on.
    I'm wandering what i can do about this problem as it didnt happen before the car went in, but it has maybe been 2-3 weeks since it was in for service, as i have been away also.
    any ideas what the problem could be and what to do about the dealer?
    P.S. it has a 3 month old battery. not years old
    Bite off more than you can chew, then chew like hell - Peter Brock
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    So does it do it when only cold or after it's been running for a while as well? What did they do for the service? They may have replaced spark plug leads in the wrong order, overtightened spark plugs causing them to crack and then arc.
    This is the reason why I do things myself and don't let a Holden dealer touch my car. Either way you should take it back and argue the point.
    Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
    Don't be stupid. Power isn't measured by the size of your tacho
    HSV VT GTS
    Dec 2008
    yeah only when cold, but the engine light came on when it was running hot. the rough idle goes away when warm but that was strange when it coughed and the engine light came on.
    it was just a full service. i dont know exactly what they did it was just the 120,000km service.
    Sep 2006
    If you haven't tinkered with the car after the service take it back! But pop the hood and just have a look around make sure all the hoses are tight and connections are in properly but don't start ripping stuff off. Did it start doing this the day after the service or a couple weeks down the track?
    HSV VT GTS
    Dec 2008
    it got home fine when it was still warm, but the next time we started it when it was cold it was like this. havent touched anything.
    just got it home fine, then everytime since when it is cold it will barely hold an idle.
    once it is driving it is fine, but when idling when cold, it is really rough.
    Mar 2005
    South Coast, NSW
    If you got the engine light on the dash then more than likely the computer has stored an error code. In the VS checking for errors codes is as simple as using a paper clip. VX shouldn't be that much different. At least once you know what the error code is you can look it up and see what the problem is.
    HSV VT GTS
    Dec 2008
    ok now there is another problem. the key will not unlock the doors to the car now. have to manually use the key to unlock the door.
    when i do get into the car the alarm light stays full on not flashing and the alarm doesnt go off.
    until i try to start the car, then the alarm comes on while the ignition is on, but goes back off when the ignition is off.
    please help, i cant start the car now and cant get it back to the dealer?
    the battery is new so it cant be that. immobiliser?
    D-Man's Avatar
    D-Man is offline All over it...
    99 VT Calais II v6
    Aug 2008
    Melton, Victoria
    Quote Originally Posted by muggo05 View Post
    could be the battery in the key itself? my brothers doesnt work... but he doesnt have that problem with the alarm.
    definately take it back to holden and get them to fix it.
    shouldnt be spluttering and crap
    Quote Originally Posted by danja View Post
    PS. All girls are the devil. It's science.
    HSV VT GTS
    Dec 2008
    well thats the thing, i can't get it back to holden! lol
  1. Servicing my VT
    By Big_Lebowski in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-06-2011, 07:43 PM
  2. servicing
    By satos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-05-2008, 08:27 AM
  3. servicing
    By Chaddy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-12-2006, 08:46 PM
  4. VS Servicing
    By BlueBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2005, 09:41 PM
