Page 1 of 5 12345 LastLast
Results 1 to 25 of 122
Like Tree1Likes
Thread: VY irs into a VT
    vt exective
    Oct 2006
    Default VY irs into a VT
    VY irs into a VT-100_8673.jpg[/PHP]Click image for larger version.
    Ok for all you who asked for the pics of the rear end of my car here you are ,hope that helps you ,i got awheel alignment today ,he said to me that he will set it to the specs of a VY .Final Values front LH - total toe +0.4mm individual toe LH +0.2mm RH +0.2mm Camber LH -0053 RH -0014 Rear Axle Total Toe +0.7mm individual toe LH +0.5mm RH +0.2mm Camber LH -0126 RH -0105 so hope that helps ,The car feels totally different best thing i ever did
    VP Executive R-spec
    Jan 2005
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    That is awesome! Something I spose I'll look into, Was it completely bolt in on the VT?
    Curious If I could put that setup into my VQ, I've busted another IRS cradle...
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    vt exective
    Oct 2006
    Quote Originally Posted by HoZy View Post
    yes everything bolted up perfectly just had to get a VY tail shaft as mine was different other than that best money i ever spent hehe ..dont bother with putting in cambers just try to get hold of complete irs VX series 2 on to VY and put it in i did mine myself took about 12 hours just taking my time did the lot myself so its not that hard....
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by glowworm View Post
    I've done 1 cradle in this VQ, so this will be my 2nd
    My last VQ did 3 cradles lol
    An my camber is really bad right now, so if I can attempt to adapt this setup it'd be nice!
    VX 'S' S1
    Apr 2005
    South East,Victoria
    You might have to rework it a bit as the VT / VZ has a wider track than the VQ
    VT series II
    Mar 2006
    sorry if this been asked but what's the advantage of this set up ?
    vt exective
    Oct 2006
    Quote Originally Posted by nilprapai View Post
    should stop tyres wearing out like they do on a VT as you get to much camber...
    VT Calais V6
    Aug 2007
    HSV +6
    Mar 2006
    Mornington Peninsula
    The complete IRS set up is needed, and if you get a VY or VZ you need the tailshaft.
    Hmm, if you get a VXs2 IRS set up would you need that tailshaft or could you use yours?
    vt exective
    Oct 2006
    the cost is not inportant if you are going to keep you car ,as for the price of tyres every year or so ,well i want mine to last and this is the best way to make sure they do .You shoud be able to get a complete irs for around
    $400.00 to $800.00 ,,,
    vt exective
    Oct 2006
    D-Man's Avatar
    D-Man is offline All over it...
    99 VT Calais II v6
    Aug 2008
    Melton, Victoria
    cheers mate !!!
    Quote Originally Posted by danja View Post
    PS. All girls are the devil. It's science.
    HSV +6
    Mar 2006
    Going to start hunting this weekend, the wreckers were no good so hopefully somewhere else will help.
  15. #15
    vt exective
    Oct 2006
    Quote Originally Posted by And_ROOS View Post
    There should be heaps of wreckers down frankston way that have a complete irs ,if not what about dandenong they should have heaps?
  16. #16
    VZ Exec Wagon
    Jun 2005
    Perth, WA
    I was gonna get 4 point adjusters on the back of my vxs2 but i read somewhere that they can knacker the diff is this correct?
    VZ Wagon (dual fuel)
    Lowered on lovells springs
    VE SSV rims
    2 1/2 stainless exhaust with DD exit
  17. #17
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    if they aren't adjusted at all after instalation, then possibly - too much toe and/or camber will do that.
    A 4 point (or 2 point) kit may not completely remove your camber issues as the VT IRS was poorly designed. VX series 2 onwards fixed this and therefore have no camber issues and don't need these adjustable bushes that don't do much (most of the time).
    forgot that you need a front and rear wheel alignment after that, should cost you over $100. So $450 (below) is pretty good for parts, labour and wheel alignment.
  18. #18
    VZ Exec Wagon
    Jun 2005
    Perth, WA
    there is a place here in perth that can fit a 4 point kit for $450 that includes wheel re-alignment.
    VE SSV rims
  19. #19
    vt exective
    Oct 2006
    Quote Originally Posted by neobristol View Post
    Are you going to keep your car ?if so then i wouldnt bother with a camber kit i would try to get VY irs , i too had a caber kit but it didnt fix the problem yes it slowed it down but that was it ,i am keeping my car for a very long time so i got myself a VY rear end best thing i ever did ,and i tell everyone it is the only way to go for thhe cost off a little more than you are paying for your camber it
  20. #20
    HSV +6
    Mar 2006
    Hated to bump an old thread, hopefully someone can reply in here unless im forced to start a new thread.
    ANYWAY, i bought a VZ V6 Lumina IRS and Diff set up to put in the VT S1 V6 to correct camber. Is there anything i need to know before this gets put onto my car?
  21. #21
    VS Calais & vh sl
    Dec 2006
    deception bay
    glad you did revive it cause i wouldnt have seen this!!
    I too have a question.
    Whats to stop you using the vt diff so there is no need to change tailshaft??
  22. #22
    HSV +6
    Mar 2006
    Glad i revived it too, how hard was it Glowworm to put the VY IRS into your car? Or is it worth a noob like me having someone else do it as im not sure i have all the equipment here. Basically i want the IRS and stuff taken from the VT and put in the VZ IRS and diff with my lowered springs and shocks.
  23. #23
    VT SS S2 A4
    Aug 2005
  24. #24
    HSV +6
    Mar 2006
    Considering my car sits quite low and it chews threw tyres, no its not. It also means i can chuck 18s on etc etc and not have to worry about needing to replace a tyre 1/3rd of the way into its life because its got horrible camber wear.
  25. #25
    VY SII HBD Calais L67
    Dec 2006
    The cradle will bolt straight up to the VT chassis. The VT diff will also bolt directly in to the VZ cradle no issues. I recommend cradle mount bushes and trailing arm bushed before fitting it to the car. You will never rip it out to do them again later lol. It's a very worthwhile conversion, you won't regret it.
    VYII Calais L67
