Results 1 to 14 of 14
Thread: leaking fluid
    VT S
    Aug 2009
    Default leaking fluid
    I've just recently bought a VT S, and have noticed some fluid leaking from under the car. I don't know much at all about cars and I'm not going to pretend to. This is the first car I've owned, so hoping someone could help me out. The fluid seems to be odourless and pretty much just like water, but there was quite a lot of it. I was thinking possibly power steering fluid?? But I really have no idea.. Any help would be greatly appreciated.
    VT spac super6
    Nov 2008
    Riverton sa
    Nice choice of car man
    and to the point,
    if its power steering fluid it will be red in colour
    have you noticed roughly where its leaking from?
    it sounds stupid, but try tasting it.. like just a tiny bit on your finger it could just be condensation coming from the heater box
    nick3110's Avatar
    nick3110 is offline 2.5" Catback
    VX Berlina S2
    Nov 2008
    VT S
    Aug 2009
    Quote Originally Posted by nick3110 View Post
    did you have the A/C on before you parked on the spot? lol
    Haha good point, no it wasn't turned on, but there was a reason I was thinking it could be something to do with the A/C. I just picked up the car today after the A/C was repaired yesterday. As I said I don't know a lot about cars other than what I like, so I'm no sure if this makes any difference or not. Cheers for the help
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Most fluid in your car are oil-based, and will stick around.
    Engine oil will be sticky and black, power steering or transmission fluid is slightly less sticky, but will have an odour. Brake or clutch fluid rarely leaks.
    In all likelihood it's from the aircon. When the aircon has been running cold, humid air will condense on the cold parts and drip water out when you park. Nothing to worry about.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    VY SII HBD Calais L67
    Dec 2006
    If the fluid is dripping onto the ground round about the left side of the transmission and is evaporating with no marks left the next day it will be condensation from the a/c compressor. Like the others said, dark oil with a mechanical smell is engine, trans is abit lighter reddish colour but will have an almost sweet smell to it. Either way, don't stress because that's what commodores do from time to time lol
    VYII Calais L67
    VT S
    Aug 2009
    OK, I checked it out a bit more thoroughly yesterday and there's a leaking hose, I think it's a radiator hose.. It's the really thick one anyway. I took it for a drive then came back and popped the hood and heard a spitting noise, and the hose was leaking bright green fluid (which is radiator coolant right?) But it has been leaking a huge amount of fluid on to the ground, could all this be from the leak? And also could I have done any greater damage than a stuffed hose? Thanks
    danja's Avatar
    Jan 2006
    Ha! I can't believe I didn't think of coolant the first time I replied
    Yes, a green, watery fluid will be from your cooling system. There are two large hoses at the front of the engine (one near the top, and one nearer the ground) which carry coolant between the engine block and the radiator. Like all rubber hoses they deteriorate over time and develop leaks.
    When the system is at operating temperature, the entire system becomes pressurised, which will exacerbate any leaks, and can easily result in large amounts of fluid being lost quite quickly.
    In terms of damage done, provided the engine hasn't severely overheated from a lack of coolant, you should be fine. The VT will sound an audible warning when the engine temp goes over about 115 degrees (normal operation is about 90 degrees), and even then if you pull over right away and top up the coolant you will be fine. If you keep driving and the engine gets too hot though, you can damage the internals.
    Get the hose fixed ASAP, and while you're at it I'd check the condition of the heater tap and other coolant hoses which could be on the way out.
    VT S
    Aug 2009
    Quote Originally Posted by danja View Post
    Cheers mate! I haven't had any temperature warnings so hopefully it's all good. Just quickly, any idea how this would cost to fix up and how long it would take to get done? I'm assuming it's pretty simple
    danja's Avatar
    Jan 2006
    Quote Originally Posted by jake_h03 View Post
    Yeah, dead simple.
    If it's just one of the radiator hoses, I'd expect about $30 for the hose, $10 for coolant, and about half an hour labour to fit it and bleed the system.
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    If the hose is held on with a screw 'worm' type clamp, try tightening it a bit more to stop the leak, till you get the problem fixed properly.
    vt berlina series 1
    Sep 2008
    check your radiator tanks as well as they can crack/split and coolant can run down
    D-Man's Avatar
    D-Man is offline All over it...
    99 VT Calais II v6
    Aug 2008
    Melton, Victoria
    if it was just the hose most likley not,
    you should have had a warning light come on if the coolant was getting dangerously low. by the sounds it hasnt so you should be right,
    just check that the hose is done up tightly... half a turn or so could be the difference between having to buy or not buy a new hose for $30 or w/e (might be cracked in that case get a new one - but no point wasting money.)
    PS. All girls are the devil. It's science.
    s1 vt
    Jul 2005
    which wanring light is to signify the low coolant level? ive never seen one?
  1. Leaking Fluid..
    By Lukie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2010, 02:06 PM
  2. Car leaking a lot of trans fluid
    By VS_Wagon_Baby in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2008, 10:39 PM
  3. Leaking Pink Fluid
    By Vz_ChiC in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-11-2007, 08:30 AM
  4. Fluid leaking under Dashboard in VH
    By veeque92 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-08-2006, 06:06 PM
  5. Leaking Tranmission Fluid
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-08-2005, 02:48 PM
Tags for this Thread
