Results 1 to 3 of 3
Thread: Coolant getting sucked up
    VE Sv6
    Mar 2007
    Werribee
    Default Coolant getting sucked up
    Hey guys, im having to replace my coolant at least once a week at the moment. Under the hood is sprayed white shit everywhere. any ideas where this could be coming from or how to fix it?
    VY SII HBD Calais L67
    Dec 2006
    May be intake manifold gaskets leaking at the front of the heads and getting onto the accessory belts. Have you had look under the oil fill cap? If it looks like the foam off a cafe latte you have bigger issues like a possible head gasket.
    You could try a coolant system sealant in the radiator but it's only a band aid fix. A mechanic can do a few tests to diagnose the issue
    VYII Calais L67
    VE Sv6
    Mar 2007
    Werribee
    Default found
    I found the problem, turned out to be a split heater hose. 20 bucks from repco, job done...cheers guys
  1. Coolant
    By INDACLUB in forum LSx Development and Modification
    Last Post: 01-04-2009, 08:25 AM
  2. Still ****ing out coolant. What could it be?
    By StockoVRWagz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2008, 07:58 AM
  3. coolant
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-01-2006, 07:21 AM
  4. And you thought vacuum gauges sucked
    By 82VH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-11-2005, 04:47 PM
  5. Blues kill Maroons HAHAHA sucked in QLDers
    By Julie in forum The Pub
    Last Post: 09-07-2005, 09:35 PM
