Results 1 to 17 of 17
Thread: Smoke coming out the air vents !!! HELP !!
    VT series II
    Mar 2006
    Default Smoke coming out the air vents !!! HELP !!
    Hi guys,
    Car: VT V6, Exec, 1997, Manual
    for the past few days, every morning seem to be some kind of smoke (condensation ?), little smell (not really electrical burning smell) coming out from behind the dash, center air vents.. and before you guys asking, the fan switch is off and it in recirculation position or if i turn the switch to let the outside air in, i can see more smoke. but !! when i turned the a/c on, seem to be the smoke/condensation disappeared
    what you guys reckon ??
    s1knt is offline Banned
    vt senator
    Dec 2008
    whitch vents is the smoke comming out of? example centre, drivers side ect.
    TrEnNaVY's Avatar
    TrEnNaVY is offline Donating Member
    VY S V6
    Nov 2008
    your car is on fire!!!
    Quote Originally Posted by ChargedVX View Post
    I've got the missus opiniion but that doesn't count
    Forecast For Tonight Is Alcohol, Low Standards And Poor Decisions.
    VT series II
    Mar 2006
    Quote Originally Posted by TrEnNaVY View Post
    lol it happen everyday for the past few days.
    Quote Originally Posted by s1knt View Post
    behind the dash, center air vent and cluster surround
    VX II Calais
    May 2009
    West Sydney
    my old xr8 did that a bit. got it cheked out cant remember wat it was now but nuthin major. some kind of condensation or sumthin. had me worrried for a bit
    5.7L VX II Calais ,Tungsten,Vy SS Rims,Full cream leather,Twin,2.5" Redback Catback,Pacemaker 4 to 1's,5% Tint,Chromed Grille
    VT series II
    Mar 2006
    i'm pretty sure that smell is the coolant smell coming through the cabin. any ideas how to look for a leaks or heater hose from the engine connected to the cabin?
    thanks
    vt executive
    May 2008
    okay my car had that problem everything was checked and came down to being intake manifold gasket my car would also on the odd occasion shoot up to hot for a few seconds then return to normal temps had the intake gasket replace cant tell you if it fix the prob as the fucing clown who fixed it didnt put oil back in the car so that motor is no more atm
    VT series II
    Mar 2006
    had a chat with one of my mate, he reckon the heater tap could stuck open? that's why i can smell the coolant. also, had a chat with my mechanic, he reckon the heater hose that running to the air condenser (the thing under the passenger dash) could be leaking..
    by the way, i don't think the intake manifold gasket caused this
    vx supercharged
    Feb 2009
    it sounds like a blocked evaporator check the drain hose under the dash with a straw
    VT series II
    Mar 2006
    Quote Originally Posted by dannyn12 View Post
    Thanks mate, where the drain hose ? inside or outside the car?
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by nilprapai View Post
    thanks
    You'r right,it is the coolant smell,i've got exactly the same smell coming thru when i turn the heater on,but funny enough havent lost a drop of water nearly two years..
    Jan 2008
    NSW
    VT series II
    Mar 2006
    Quote Originally Posted by fr3ndlyfir3 View Post
    you need to replace the heater core
    so, you reckoned the heater core ?
    vx supercharged
    Feb 2009
    if it was your heater core there would be a coolant leak inside the cabin and your coolant level would drop to have access to the drain plug get under your car below the dash and you will see a small opening that is the drain hose
  15. #15
    VT series II
    Mar 2006
    Thanks mate, will have a look tomorrow
    4.2 vt executive
    Aug 2009
    Default smoke coming out the air vents !!! help !!
    Quote Originally Posted by VT_Acclm View Post
    hay man, have you found out what the coolant smell is when the heater is on cause mines doing the same thing and i cant find a leak anywhere
  17. #17
    227shanno's Avatar
    227shanno is offline Donating Member
    vy ss 5.7
    Aug 2009
    wollongong
    Yeah its your heater core and its very expensive to fix most places wont touch them. if you got airbags and AC then your looking at $600 to $800. they gotta take the whole dash off disconnect everything its like 7 hours labour.happened to my car, just got the core bypassed
  1. steam coming though the vents
    By MR__CALAIS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-04-2009, 07:35 PM
  2. Noise coming from heater vents
    By shinagami2227 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2008, 07:24 PM
  3. Steam/SMOKE?!? Air vents.. VT
    By Christina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-12-2006, 03:31 PM
  4. no air coming out of vents
    By lilmoz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-06-2006, 11:16 AM
  5. Smoke Coming Out Of Air Condition Vents
    By fergi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-07-2005, 07:24 PM
