Is this a good camber kit for a VX commodore? Are they 4 point or 2 point kits?
Anyone used em?
Cheers.
Chris.
This has been covered many times before, it's called the search function, but anyway.
I'm assuming you have the sries 1 VX as the camber problem was corrected in the series 2.
If it is camber that you are trying to fix then get a 2 point kit as that is all you need. if you want more adjustment than that (toe as well) then get a 4 point. it dpeneds on your needs.
They will NOT however always completely remove the camber issue, which is why I am eventually going to replace the whole IRS in my VT with one from a later model (VX II onwards)
Oh and as for brands, there isn't much difference. Most are polyurethane bushes. I don't see how one can offer more adjustment than another as they must still fit in the same amount of space including enough room for the bush to do its job
