Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: what have i done? blown head or engine??
    vt executive
    Aug 2009
    Unhappy what have i done? blown head or engine??
    LAST NIGHT i pulled my commodore 97 vt up to drop my son off and the temp gauge went straight up to hot like with in 10 seconds.Turned engine off. i had to move my car off drive way and then turned it back off and then when i parked it all this horrible light brown stuff was on the road. well i figure it was a mix of oil water and coolant. it came out the place where you put the coolant in. when the car cooled down i took radiator cap off and more of this stuff come out of there. i only had car for 4 months and love it. has been running perfect with out missing a beat till that moment i pulled up. what do you think it is. your advice will be greatly appreciated.
    the stuff that came out of the radiator was thick and creamy, light brown with oily consistency. looked nothing at all like water or coolant. just wanted to clear that up.
    another point is just before it happened the gears didnt want to change like normal like was havign trouble changing up a gear and reving the motor a bit. i was only doing at most 50km p/h at the time.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Welcome Sonia.
    First check your engine oil, pull out the dipstick and see if the oil is a normal colour or milky.
    It's hard to say what is wrong without seeing it but maybe you have a hole in the radiator.
    MY RIDE
    vt executive
    Aug 2009
    hi thanks
    i checked the dipstick last night there was little oil in it but looked normal
    vt executive
    Aug 2009
    the stuff that came out of the radiator was thick light brown stuff nothing like water
    VT S Supercharged
    Jul 2009
    I think the corrosion inhibitor will turn the coolant brown when it gets old. Sounds like you may need to get the radiator flushed, if there are no other problems, and a coolant change.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Sounds like a head gasket don`t drive it and get it looked at asap.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    Sash182 Guest
    I had the same prob with my old vt. turned out to be a faulty thermostat sticking
    vt executive
    Aug 2009
    did it fill up will oil and spew it all out??
    i checked my transmission fluid that seems to be a greyish colour not red as i thought. would it change colour at all.
    thanks to all for there answers so far. it is muchly appreciated.
    i actually live in devonport tasmania. no any good mechanics down here?
    VY S L67
    Nov 2007
    old dexron will be grey to black or brown instead of red.
    could have a radiator end cap leak, affecting the trans fluid too
    vt executive
    Aug 2009
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    short distances and low speeds won't do it any harm. It might say something about it in the user manual.
    It sounds like a sticky or stuffed thermostat to me. If the oil looked reasonable then it's safe to assume the brown crap was just years of sludge and inhibitor in the cooling system. If you try to hose it off the driveway does it do that funny thing oil does when you try to hose it off? Gets a sorta glaze of bluey-white to it and is a prick to remove....
    vt executive
    Aug 2009
    Quote Originally Posted by vlv8vic View Post
    yeah we hosed of the drive today didnt move with just water so we put degreaser on ot and most of it went. yeah it had prety colours in it
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    sounds like oil then. could be trans fluid though which means a stuffed radiator. New rad an tranny service should suffice. (i assume trans cools through the radiator on a vt.. never looked....)
    vt executive
    Aug 2009
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by soniamaree1969 View Post
    so how much trans oil would the car hold
    It holds 7.9 litres including what is in the torque converter, 4.8 litres for a service refill.
    MY RIDE
  16. #16
    vt executive
    Aug 2009
    wow really that much. well i suppose i hope it is that and not the head gone. well going to get it off to mechanics tomoro now and hope it not gonna cost me tooo much. dam cars. wish i didnt need it. thank you for your help.
    will let you know the diagnosis from mechanics
    thanks all
  17. #17
    VN Calais
    Jan 2009
    Melbs
    If your temp gauge is going through the roof + sludge, I would get the car towed to the mechanics....
  18. #18
    vt executive
    Aug 2009
    VS_Pete_1's Avatar
    Dec 2007
    Good luck keep us posted
  20. #20
    vt executive
    Aug 2009
    vt executive
    Aug 2009
    well it was the tranny. oill in to the radiator and water into the tranny. new radiator and flushing out the system. cost $500
  22. #22
    VS_Pete_1's Avatar
    Dec 2007
    Good outcome I`m happy for u.
  23. #23
    s1 vt
    Jul 2005
    same thing happened to me, the end tanks on the radiators are plastic and when they breakdown you get water in tranny and dex3 in the radiator, new radiator i got for $260 so it doesnt seem so bad.
  24. #24
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    mine had been doing this for awhile, just cracked the radiator yesterday, as said above the transmission cooler tanks (one for series 1 or twin tanks on series 2) leak into the coolant and you find sludge crap on the underneath of the radiator cap.
    SO iv got an SSS racing radiator lined up to pick up tomorrow for $130
  25. #25
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    make sure u change thermostat to, my father had a vs ute, radiator blew from overheating, bought a new, drove it, blew it up again, then bought 3rd one, and forgot to put thermostat back in and it was all fine, lol never forgetting that again
  1. Cracked head? blown head gasket???
    By VL_5SPEED in forum General
    Last Post: 09-01-2010, 10:41 AM
  2. new engine after head gasket blown
    By nickg777 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2009, 12:32 PM
  3. Blown head gasket or cracked head
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2006, 07:52 PM
  4. blown head
    By crazy for vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-08-2005, 06:28 PM
  5. blown head?
    By vr_chaser in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2005, 10:29 AM
