Results 1 to 7 of 7
Thread: Wont change gears in drive
    Jan 2008
    NSW
    Default Wont change gears in drive
    ok... so i had my heater core changed by holden for $1000.
    Anyways on the way home i noticed that at full throttle it was very sluggish. It didnt rev as quick as it used to. It holds the revs at 4500, doesnt peak out and doesnt change gears.
    My mate says maybe the computer just needs a little time to adjust after the battery been out so long and all.
    And after about an hour of driving it was back to normal. It was perfect, as if nothing was wrong.
    what are your thoughts on this???
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Check you transmission fluid mybe it is low.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    Jan 2008
    NSW
    Quote Originally Posted by VS_Pete_1 View Post
    will do mate. But i dont think that the problem I've had the car 3yrs and this is the first time i,ve actually had a problem, straight after suttons worked on it.
    VS_Pete_1's Avatar
    Dec 2007
    Some times when a tranny doesn`t change gear it can be a solenoid on the tranny.
    Mybe talk to suttons mate??????
    Jan 2008
    NSW
    the weird thing is it was only like that for about 30mis to an hour after that it changed like clockwork.
    I went for a cruise yday and it was perfect. I will definitely tell holden though. I have to go back on monday coz after they worked on it my instrument cluster wont light up. I told them when i picked it up their fixing it for free, also one of the dash panels doesnt sit right. So gotta tell em bout that as well.
    VS_Pete_1's Avatar
    Dec 2007
    Yep sounds like they have done something.
    Let us know how u get on please.
    Good luck.
    Jan 2008
    NSW
    Good luck.
    Well like i said above it was like that for only about 30mis or so its been 2 days now and its fixed itself, it perfectly fine. But will definitely let them know about it. See what they say. Also have it put in writing that if it happens again soon that they will take a look at it and fix it for free. One thing i have learned In my 3 short yrs of owning a car is that verbal confirmations dont mean sht. Get it in writing.
    I'll let you know how it goes.
  1. Car wont change gears, holds gears, and rough changes
    By pedrotski in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2008, 06:35 PM
  2. Dumb question about Drive gears.
    By Stephen_Vn_Exec in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-05-2007, 09:27 PM
  3. drive gears - vh
    By vh ~ very horny in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-03-2007, 08:17 PM
  4. T5 speedo drive gears
    By vkberlina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-06-2005, 11:04 PM
  5. Speedo drive gears
    Last Post: 02-06-2005, 07:14 PM
