Results 1 to 6 of 6
Thread: radiator overflow box
    VT commodore
    Aug 2009
    Default radiator overflow box
    Hey guys i think my radiator over flow box is cracked how hard is it to remove and what do they cost new ?
    Thanks for your help
    vt s s1
    Mar 2009
    Not hard at all. Not sure exactly but should be a bolt or two if u get under the car where the bottom of the bottle is.
    Just undo those and the hose and itl pull right out.
    Just a ball park figure but from holden i reckon you might be looking round $100 maybe more
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by makavel View Post
    Go to supercheap, its called Plastic Epoxy Welder $17,two part resin ,mix it put it on 4hrs later good as new..
    vt berlina series 1
    Sep 2008
    executive vt 5.0lt
    Feb 2005
    west suburbs
    are you sure it is cracked??? i thought mine was cracked , but when i took it off, i found that it has an overflow from the box ,thats what i think is wrong with yours, if your not sure and going to take it off eny way ,run the hose throught it and you will see water comeing out where the box is , and then clean it out with hose take off box emty it out of water then refill with coolant to the right spot on the dipstick
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Yes I'd be inclined to use plasti weld or fibreglass to repair it, especially if it's in an inconspicuous place.
  1. [VIC] VN s1 radiator overflow bottle
    By h0Ld3n`VN in forum Swap / Wanted to Buy / Trade
    Last Post: 24-12-2008, 04:17 PM
  2. radiator overflow bottle.
    By lord_davros in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2007, 11:44 AM
  3. HD radiator and overflow bottles
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2007, 09:53 PM
  4. Radiator Overflow Bottle/Washer Bot
    By groucho in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-06-2006, 11:42 PM
  5. Radiator doesn't suck coolant from overflow
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-12-2005, 09:46 AM
