Results 1 to 7 of 7
Thread: VT door locks
    vt s
    Jan 2007
    Default VT door locks
    Hi when i lock my vt only 3 doors lock i have replaced the module in the door with no success any ideas what to do
    cheers
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Possibly a broken wire in the rubber boot where the loom goes from the body to the door. With the constant opening and closing of the door sometimes a wire can break.
    MY RIDE
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Is it not locking? or is it locking but the lock stays up?
    As mentioned above, check the loom with a multimeter. Connect the plugs to the end of the multimeter and unlock/lock it and see if theres power to the lock motor.
    Most common fault is that one of the locking arms (the steel rods) that connect from the motor to the lock come off. Drivers door is most common.
    vt s
    Jan 2007
    VT Wagon
    Nov 2008
    I had exactly the same issue on mine, the wires were broken smack in the middle of the rubber boot.
    It's a hell of a job to fix, mine would open but not lock so I had to lock it manually all the time. I had a look on a VX and they have changed the design of the boot and used better wires.
    When you pull off the boot it will probably tear at the end a little so have some silicone standing by to put it back on. Or you can do what I did, remove the plug and socket, join all the wires manually and use the rubber boot from a VX.
    While your doing that do the speaker wires as well because they will also break if they haven't already.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by gunk81 View Post
    The VT series 2 has the same loom as the VX, a much better design and easier to unplug without damaging the boot.
    MY RIDE
    kiwiss5L is offline Pete
    VT 5.0 SS
    Aug 2008
    central coast sydney
    had to change mine also, the window was also not working.
  1. VP door locks
    By ringfeder3 in forum Electrical Wiring / Questions
    Last Post: 14-05-2009, 07:51 PM
  2. Door locks
    By IvegotaCommy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2008, 01:47 AM
  3. Ve Door Locks
    By mmrdb in forum VE Holden Commodore (2006 - ?)
    Last Post: 26-07-2008, 12:51 PM
  4. door locks
    By Jecs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-09-2007, 03:16 PM
  5. VP Door Locks
    By lostsoul1972 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-08-2004, 10:02 AM
