Results 1 to 4 of 4
Thread: vx air /con
    vx executive
    Aug 2009
    Default vx air /con
    Hi all
    As I am new to this I was wondering if anyone can help
    The a/c only comes through the demister I have pulled out the a/c dial and there seems to be nothing wrong with it. and I have tied back the linkage under the dash to get cold air at the dash outlet can anyone tell me how to fix it if possible Thank you in advance
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    There is a thin vacuum hose which connects at the rear of the intake manifold. Check to see if it is on properly and also check the one way valve which is on that hose. That is often the problem and it's the easiest thing to check first.
    MY RIDE
    vx executive
    Aug 2009
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by thinedge View Post
    Many thanks Accentstencil I did as you said and it worked like a charm
    Happy to be of help.
    MY RIDE
