Results 1 to 4 of 4
Thread: mystery fault
    VXII Berlina Wagon 5.7/A4
    Jul 2009
    Default mystery fault
    What kind of PCM faults will cause the light to stay on constantly with no loss of drivability, It passes the startup check goes out then relights after about 5 seconds. The oil light does work, I've had that happen before..so I've counted that out...everything works as it should...good power, auto shifts fine, idles ok, no surging, traction control, cruise everything works. Vehicle is VXII V8/A4 wagon. I know I'll need to get it scanned but it has no apparent faults!! Any ideas??
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The oil pressure sensor is a common fault. I've replaced mine once and it needs replacing again but they are ridiculously expensive.
    MY RIDE
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    Faulty oil pressure switch.
    I like my roo well done
LinkBacks (?)
  1. 14-08-2009, 08:18 PM
  1. History Mystery
    By bazcom in forum Jokes/Humour
    Last Post: 03-01-2009, 12:08 PM
  2. my little mystery...
    By spd_dmn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2008, 05:20 PM
  3. Mystery box
    By Joe_222 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2007, 09:18 PM
  4. Mystery part
    By electric_monk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-05-2006, 01:20 PM
  5. Fault light came on but reports no fault
    By VRBerlina05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 07:21 PM
