Results 1 to 3 of 3
Thread: How to stop Heat from gearbox
    ascottaudio's Avatar
    ascottaudio is offline AscottAudio
    VE Calais V8
    Feb 2009
    Default How to stop Heat from gearbox
    I have noticed a decent amount of heat comes from my 6 speed manual trans as well as a bit of noise..I am thinking about how to insulate the cabin from the box a bit more than just having the gear boot..I was thinking about tin foil in regard to the heat...but I am guessing someone knows a product that would be better than this..
    Your thought are appreciated
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Hey I did the entire underside of my VY with 3.5 litres of body deadener (two coats) Some places like where you are describing are tricky to get to but well worth the hassel. This is only a thought, I am sure there are many "experts" on this forum who have better ideas! Good luck mate hey.
    kart_racer is offline Races karts
    VT Acclaim 5M
    May 2008
    My first thought would be to use a sound/body deadener as VYMAD suggested. I would be thinking something more along the lines of dynamat (a bituminous layer with foil layer).
    The stuff VYMAD is talking about is a tar like deadener you can buy in a tin and brush on or spray on. I would use this on the underside of the transmission tunnel, then layer the interior of the car over the transmission tunnel with dynamat (or a couple of layers of Flashtac from Bunnings).
    That should insulate from a fair bit of heat and noise.
  1. gearbox on VR not changing in the heat
    By ViN3Y in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2009, 07:04 PM
  2. No Heat. VS
    By robert_buntine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2006, 07:58 PM
  3. VR Heat
    By ozzie_online88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2006, 02:12 PM
  4. heat in vs v8
    By greatone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2005, 02:08 PM
  5. 202 oil heat?
    By CAFA_TF in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-01-2005, 05:15 PM
