Results 1 to 12 of 12
Thread: Alternator?
    VX Calais L67
    Jul 2009
    Default Alternator?
    I'm fairly sure my alternators gone.
    Driving home from basketball last night (20 min drive) the battery light comes on, as i'm driving along the lights start to dim ever so slowly, then the ABS and Trac control turn off, then the stereo and gps turn off, then the speedo turns off and the check engine light comes on.
    Take the train to work then go buy a new battery, go to put the battery in but figure I'll start the car first to see if it fires up.. and it does no worries, turn the lights etc on no problems, no battery light but the check engine light stays on.
    Figuring its the alternator
    its a series 1 supercharged VX
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    Check the charge rate with a multimeter if you have one if not go into the hidden menu on the display and check the charge rate there....
    VX Calais L67
    Jul 2009
    VT V6
    Jun 2008
    Wellington, NZ
    If that was checked on the battery with a multimeter, then yeah that sounds like your alternator, idle voltage should be at least high 11. If the same thing happens in a coupla days of driving as what happened to the previous battery then you'll know fur sure, but that voltage pretty much says it all imo.
    VT ll S Pack
    Jun 2009
    how do you get into the hidden menu? i think something is going on with my altenator
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Press the mode and up buttons at the same time and hold while starting the car. Keep pressing mode till you get what you want.
    MY RIDE
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    check ur alternator brushes... $50 fix
    or its around $450 for a new l67 alternator :/
    VX Calais L67
    Jul 2009
    Quote Originally Posted by don0xer View Post
    $229 for a new l67 one from repco, picked it up 2 hours ago
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    Quote Originally Posted by NickVX2 View Post
    Was it a genuine Bosch alternator?
    I like my roo well done
    VT ll S Pack
    Jun 2009
    Quote Originally Posted by accentstencil View Post
    thanks accentstencil
    ill give it a go
    BOGANV8's Avatar
    VX 02 SS LS1
    Dec 2005
    Armidale
    Quote Originally Posted by jhawk View Post
    Idle voltage should be between 13,8-14.2v for most cars Commodores included...
    Do 2 tests just to make sure check once at the battery & then check at the back of the Alt to make sure there is not a wire broken between the battery-Alt
    VX Calais L67
    Jul 2009
    Quote Originally Posted by WAGON MAN View Post
    yeah sure was, allthough didn't end up needing it, as the plug on the back of the alternator had just corroded off.. ended up costing $2.10 to fix
  1. Alternator not charging, no alternator light
    By 5L fury in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2009, 05:55 PM
  2. WTB: vn alternator
    By slayer in forum Parts And Other Items For Sale
    Last Post: 07-10-2008, 06:36 PM
  3. Alternator maybe??
    By VT97 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-04-2006, 01:49 PM
  4. VS alternator
    By CANYONERO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2006, 07:32 AM
  5. vt alternator.
    By scozzman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-04-2006, 09:05 PM
