Results 1 to 11 of 11
Thread: petrol smell
    vx executive
    Aug 2009
    Default petrol smell
    Hi all again, now! for another problem, the girlfriends vx has a bad petrol smell in side the car where do I start to look ? thanks
    Holden Commodore VT
    Aug 2009
    Check fuel lines, fuel tank and injectors for leaks. Also depends what fuel is run.... unleaded 91,95 or 98? has a VR which did the same thing.... used octane 98 from then onwards.... problem fixed.
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by thinedge View Post
    i have the same thing. let me no how you go
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    VT Executive S2
    Aug 2008
    Melbourne Victoria
    I had that problem a while ago and it ended up being the petrol cap not being tightened properly. I now make sure I grab the outside edge of the cap and give it a good twist.
    Or maybe check that the rubber seal on the cap is still in tact!
    Good luck!
    Mig.
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    ok! ill give it ago,
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    i have a vn commodore that does the same thing, only when i have over 3/4 tank, is the petrol cap suposed to hiss when u undo it? because my other commo did but this one doesnt, im thinking maybe its the cap aswell
    VT Executive S2
    Aug 2008
    Melbourne Victoria
    Quote Originally Posted by vn_v6 View Post
    Prob better to get a new cap just to be save, don't think they would cost that much to replace. And I can't say I've heard any hissing when I undo mine, maybe on hot days or something!
    VR Berlina S2
    Aug 2009
    not so much a petrol smell in the cabin but i get it if the window is down.
    My exhaust has a 2.5" crack just before the 5th exhaust manifold runner, and thats what i think mine is.
    vxss vnss
    Jun 2009
    it could be the breather lines around the neck of the filler.just a guess.had the similar problem on my vnss turned out to be the breathers.
    227shanno's Avatar
    227shanno is offline Donating Member
    vy ss 5.7
    Aug 2009
    wollongong
    could be the charcoal canister needs to be replaced, its a small box at the end of the fuel return line
    VS Ute
    Aug 2009
    Gladstone Qld
    Yer the breather on my vs was broken so this mite be the problem
  1. Petrol smell
    By kapzi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2009, 04:16 PM
  2. petrol smell with ac on????
    By Macka21 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-03-2009, 12:51 PM
  3. petrol smell
    By skyper in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-11-2008, 05:22 PM
  4. petrol smell
    By Aryashahin in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-10-2008, 12:12 AM
  5. Petrol smell in car
    By G4orce in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2006, 01:19 PM
