Results 1 to 14 of 14
Thread: VXII Alarm/Immobolizer help
    2002 VX II Acclaim
    Aug 2008
    Default VXII Alarm/Immobolizer help
    How you going guys. Ive got a VXII Acclaim with factory alarm/immobolizer.
    Now, if i sit inside my car, lock the doors, and manually pop the doors (simulate somebody breaking into my car) the alarm should go off yes?
    When i do it, it only goes off sometimes, and when it does go off, its only indicators flashing. I can hear the siren relay clicking in rhythm with the indicators, but there is no beeping!
    I also get no beeping when i lock my doors. Is this normal? Ive tried swapping out the relays and the fuses are fine. Ideas?
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Does your horn work? Because I thought that the factory alarm used the horn.
    Ronald Reagan (1986)
    2002 VX II Acclaim
    Aug 2008
    My horn works fine. Theres another horn near the firewall infront of the passanger seat. Ive checked all the connections.... All seems fine. Need to take the car in for a VIV soon and dont want them to fail me because alarm doesnt work!
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by anarklov3r View Post
    Disconnect the horn near the firewall and connect 12 volts to it to see if it works. I don't think you will fail the VIV (whatever that is) if the alarm doesn't work.
    MY RIDE
    2002 VX II Acclaim
    Aug 2008
    VIV is the pits by vic roads. I was told car has to be 100% in line with manufacturer specifications if i want to pass the ViV test (car was written off) and get it registered
    VX Executive S2
    May 2006
    Frankston South Vic
    I think there is a time delay (30 seconds?) that if you open the door in that time the alarm wont go off. if you can hear the relay clicking but no horn noise then possibly the relay tips have failed
    2002 VX II Acclaim
    Aug 2008
    Ive tried swapping out the relays with other matching ones front different systems that i know work, and still no go! Tomorrow when theres daylight im going to try hook up 12v to the horn see if it works.
    And lout, i tested the alarm by sitting in the car, locking the doors, waiting a couple minutes, and then opening the doors. no go.
    Hot-Rod's Avatar
    Hot-Rod is offline SuPaFlY -LiV3 Surviv3 Di3
    VX Commodore Series 2
    Sep 2005
    Oz
    Anarklov3r when you lock your doors you shouldn't get a horn noise, never have in my car, same with unlocking, no horn.
    1 flash from indicators when locking
    2 flash from indicators when unlocking
    Ray De Man's Avatar
    Ray De Man is offline Donating Member
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    My alarm works with sound from siren.
    Two beeps for un-arm and flashes from lights twice
    One beep for arm and static lights flash once
    Horn only really sounds when car is locked. If you open boot wait 30 seconds or so, lift up bootlid and horn will sound.
    2002 VX S pack
    Sep 2009
    Is it possible to rig up the factory alarm to sound the horn when you lock and unlock it? thanks.
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    ive also wanted to know if its meant to make noise
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    2002 VX II Acclaim
    Aug 2008
    hook up a relay to the output on the BCM that sends power to the central locking actuators. That way when doors lock / unlock it will beep as many times as it flashs. But when you dead lock your car, you will get one LONG beep. lol
    WK Caprice
    Sep 2009
    Yeah mate you can make the horn sound when you hit unlock and lock by going through the factory menu depending on the model of your car if you hold in the menu button with ignition off and hold it in turn the ignition to on this should come up with a menu on your dash. scroll through it untill you find the lock unlock function.
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    ive never seen the lock / unlock function on mine
  1. VXII Factory fitted alarm question
    By mourati in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-09-2009, 09:25 PM
  2. VXII VY VZ Factory Siren Alarm Question Plz
    Last Post: 13-05-2009, 08:07 PM
  3. VXII help
    By HVXII in forum VT - VX - VU - WH - V2
    Last Post: 04-08-2006, 10:27 AM
  4. VXII S/C - What should I mod first
    By vagure5 in forum V6 Development And Modification
    Last Post: 28-05-2006, 07:48 PM
  5. vxI ss vs. vxII ss
    By trepaul in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-11-2005, 01:21 PM
