G'day, I have a VT SS series 2 LS1, i'm thinking about going the Altezza route for the rear tail-lights, I know there are 3 different styles to choose from, 1 is non ADR compliant so that rules that one out, 2 LED lights and 3 monaro style lights, my question is I have the Globe failure feature in my car and i'm wondering if I went the LED option would that cause a problem,I do remember seeing some guys advertising that some of their lights should not be used with the globe failure feature but can't remember which lights they were or who the seller was so I can chase it up. Can anyone enlighten me please.
Les
Really need an answer from the electric experts on this one, don't want to blow a couple of hundred bucks on lights I can't use.
Les
I hear voices in my head and they don't like you
Yes it will cause problems.
You have 2 options though with the LED's
You can either get an electronic relay or you can get an LED resistor for each side.
Youll only have problems with the indicators flashing fast asif a globe is blown.
Brake and reverse lights shouldnt effect the globe failure.
Thanks Ozzie, looks like monaro style with globes then, did the LED relay stuff to my Harley won't go down that path again.
Les
