hey im about to buy a vu spac ute and im wondering if it will have an LSD? I'm asking because i will be transplanting my l67 engine and the auto into it and i dont think 350hp on an open ended diff is good.
You're in luck, the S comes with an LSD from the factory![]()
The S doesn't come standard with an LSD. It was an "option" that not many gaybe S pack buyers ticked at new unfortunately.
FYI the Ecotec and L67 trans are identical, just the stall converter is the difference. Might be easier ifr you if the VU has less kms than the car your L67 and trans came from to just plonk the L67 and its stall in front of the ecotec box.
The stock box will have issues holding up tp your forcast 300rwhp anyways so you may at least want to shift kit it and ft a larger trans cooler before the engine goes in.
VYII Calais L67
na my trans atm was rebult last november with stroger crap and im running a 2800Rpm stally. plus the auto in the vu is matched to the pcm so when i put mine with it it would have a s**t fit with my l67 one
